Calling all electrical gurus!! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-13-2013, 10:45 AM Thread Starter
EflumE's Avatar
Quoted: 29 Post(s)
Has anyone ever attempted to make a remote for a winch?
I can't find mine but I'm thinking it wouldn't be to difficult to make one. It's just a three prong plug. forward, backward and neutral.
Any ideas?
-Eric-
96 cclb, baby swamps, TS 6 position w/swamp's tunes, billet wheel, 1.0 housing, diy ebpv delete w/plugged pedestal, 3" downpipe to 4" exhaust, 6637, boost, egt, trans gauge, fully built trans, 203* tstat, 08 diff cover, airlift helper springs
218,000
9 inch skyjacker on 37" interco M16's
EflumE is offline
post #2 of 5 Old 05-13-2013, 11:28 AM
tysonxj is offline
post #3 of 5 Old 05-13-2013, 11:57 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Need a plug to connect and the type of winch may help find the diagram to make the wiring
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 5 Old 05-13-2013, 04:41 PM
ChiefRocka's Avatar
Use a test light to determine if its a positive or negative trigger.
Basically, just a switch controlling a solenoid pack.
Perfect switch to use would be a Carling 3 prong ... I have quite a few
I can hook u up !
John
2002 F-250, CCSB, 4" Exhaust, Stock otherwise
ChiefRocka is offline
post #5 of 5 Old 05-14-2013, 06:29 PM Thread Starter
EflumE's Avatar
Quoted: 29 Post(s)
cool. i figured it would be easy but im not real bright when it comes to electrical stuff.
it's a warn 10000
I'll check it out
-Eric-
218,000
EflumE is offline
