Engine difference? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-12-2013, 06:43 PM Thread Starter
Engine difference?
Hey guys on my title my truck says its a 96 f250 but on the side tag I'm the dorr it says like Oct 95 and the little front end plaice where radiator mounts says Oct 5 1995. Also on the front cover in the little stamp it is stamped 95. I was just wondering because I bought a fuel bowl re seal kit and it says the bowl are a little different. So is there a difference? I also heard something about different hpops. Is there anyway I can see what it is? Like is there a noticeable difference? I'd like to know what year to say at the parts store. I really hate when a truck is a late year and they title it the next year.
96 f250 rclb flatbed, 4x4 5spd, Custom CAI, 4 inch exhaust, and soon when I make more money, gauges, ts 6 pos with tunes, baby swamps or rosewoods stage 1s.
OBS96stroker is offline
post #2 of 11 Old 05-12-2013, 06:53 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Late 94-e95 don't have the anti drain back like the late 95-03 on the hpop, not sure on fuel bowls
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 11 Old 05-12-2013, 07:02 PM Thread Starter
Well I'm guessing Oct is late year? I hope so, can you tell a difference between drain back and non drain back?
post #4 of 11 Old 05-12-2013, 07:15 PM
PSDTV21's Avatar
I think think bowls are the same. I have a 94 one and a 97 one and if needed i can check tomorrow
Sent from AutoGuide.com App
-Tyler
1994.5
Efuel, Valair 500hp, D60, Hydra w/PHP tunes
PSDTV21 is offline
post #5 of 11 Old 05-12-2013, 07:39 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Mine are not side by side otherwise I would check, and something about the front cover being different for the hpop
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 11 Old 05-13-2013, 06:13 AM Thread Starter
We'll if either bone of you don't mind to look if your not busy it would be much appreciated...
post #7 of 11 Old 05-13-2013, 06:18 AM
PSDTV21's Avatar
I'll look for you when I get home. There is a difference in front covers I'm just not sure what's different. I do know that if you switch to say a 97 front cover you can use a super duty hpop though
-Tyler
1994.5
PSDTV21 is offline
post #8 of 11 Old 05-13-2013, 06:28 AM
Quoted: 48 Post(s)
Date of manufacture is irrelevant. Model year is what's relevant. For the last 50-ish years, they start building the vehicles of a given model year approximately August of the previous calendar year. So seeing October 1995 on a 1996 truck is exactly what one would expect.
madpogue is offline
post #9 of 11 Old 05-13-2013, 04:45 PM
PSDTV21's Avatar
From what I can tell there is only slight casting differences between the bowls. Although I noticed the FPRs are not the same
-Tyler
1994.5
PSDTV21 is offline
post #10 of 11 Old 05-13-2013, 06:02 PM Thread Starter
So my truck is a 96... just looked a little weird because the little stamp on the motor was cut out on 95.
