EBPV question.... - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-12-2013, 10:22 AM Thread Starter
EBPV question....
I am planning on disabling the EBPV; will be ordering the termination plug from DFuser soon.
I want to wire the valve OPEN, but how can I tell what position the valve is in?
97 F250 PSD...6637 Filter upgrade...3" Diamond Eye DP...DFuser EBPV eliminator...Improved "Blue" CPS...
Qwazert is offline
post #2 of 4 Old 05-12-2013, 10:52 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Pull the down pipe and look at it, typically it's supposed to open on shut off, just unplug it while its off and it should just stay open
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 4 Old 05-12-2013, 12:36 PM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 4 Post(s)
Feedback Score: 3 reviews
Valve is normally open like Kris said. With truck off just unplug it and you should be good.
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #4 of 4 Old 05-13-2013, 08:36 PM Thread Starter
Thanks!
Qwazert is offline
