need help fast, PLEASE!!! - Ford Powerstroke Diesel Forum
post #1 of 19 Old 05-12-2013, 09:49 AM Thread Starter
nohsp4u's Avatar
I am loosing my mind....ok, maybe that was gone long ago. I have my sig truck, vacuum is gone so i am trying to get to the vacuum pump and switch to perform tests. Can someone please tell me, how to remove the bottom half of the factory air box? i unbolted one side and the other two clips look like they are suppose to just slide off Not mine. I need to get this truck back up today.
1997 F-350 XLT Lariat Crewcab long box 4x4. Oxford white with an ugly green. 133xxx miles. Hide away goose neck, banks turbo, exhaust, inner cooler, intake filter and gauges.
nohsp4u is offline
post #2 of 19 Old 05-12-2013, 09:56 AM
Maverick1701's Avatar
Send a message via AIM to Maverick1701
iirc it just unbolts. You might as well tear/cut/rip the dang thing out and replace with a 6637 filter...those old air boxes are not that great.
ChrisChris
2003 Kawasaki KLR650
1997 Ford Expedition 4x4
1967 Kaiser Jeep M35A2 6x6
2016 Silverado 4x4 Crew-Cab LS/Police
Maverick1701 is offline
post #3 of 19 Old 05-12-2013, 09:59 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The rubber boots on them just pop off
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 19 Old 05-12-2013, 11:09 AM
Quoted: 50 Post(s)
I ended up breaking some of those mounting points when I switched to 6637s on our trucks. But I'm confused as to why you need to do anything with the airbox in order to remove the vac pump.
madpogue is offline
post #5 of 19 Old 05-12-2013, 12:08 PM Thread Starter
nohsp4u's Avatar
I was trying to test it, got it tested without but now cant get the pump pully back on. the freakin tool keeps backing out and the pump turns. anyone have a suggestion as i am about out of time and will need to tow it to a shop.
nohsp4u is offline
post #6 of 19 Old 05-12-2013, 12:28 PM Thread Starter
nohsp4u's Avatar
Nothing?? That is ok. It is getting towed out of here tomorrow. And i will find out it was something so freakin simple i will out a bullet in it.
nohsp4u is offline
post #7 of 19 Old 05-12-2013, 12:35 PM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 4 Post(s)
Feedback Score: 3 reviews
Why didn't you just buy a vac pump with the pulley already installed??
When i replaced the one on my black truck a pump with the pulley already installed was cheaper than without.
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #8 of 19 Old 05-12-2013, 12:35 PM
no idea dude. let us know what the shop says....hopefully it's something simple/cheap/easy
ChrisChris
post #9 of 19 Old 05-12-2013, 01:03 PM
go inside and take a deep breath and stop thinking about it for a while. once you cool down go out and try again. that normally makes things go a little smoother for me
1997 Ford F250 CCSB. Intake. 3in dp 4in straight piped exhaust. Gauges(Pyro,boost,trans temp). Dana 60 swap
power73 is offline
post #10 of 19 Old 05-12-2013, 01:19 PM Thread Starter
nohsp4u's Avatar
I am down two margaritas at this point, sure me four real quick.
I have never had an issue reinstalling a pully with the installer tool but, this damn thing is serious killing me.
I get a few turns on the nut before the drive screw turns back out.
I just know i am doing something wrong, and now i will need to drive my wife's Acura all next week. I hate being that low to the ground.
nohsp4u is offline
