Several Questions... Mods and Pictures.... - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-12-2013, 07:28 AM Thread Starter
Ok so I am in the process of modding. I did a search but still a few questions...
Air intake. No issue here as the Tymar is the winner.
Turbo back 4 inch no cats(I am in Florida). Do I want the muffler? Opinions? Comments?
And Programmer.
Now can anyone show me pics of their install of the switch? Anyone come up with a way to tell which position they are in? (I did see the one on Beans website)
Also is the HX kit or Boost Fooler needed (I thought read where on a OBS you dont need this) ? How hard are this to install?
2015 F-350 Lariat SRW CC
Sold to my dad:1996 F-350 XLT Crew Cab
2x4 Dually 7.3 with 80,000 miles as of 3-10-15
YJSONLY is offline
post #2 of 12 Old 05-12-2013, 07:39 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Muffler is only needed if you want the sound, my 6 pos chip dangles on my dash, most put it under the steering wheel, by the headlight knob, or on far side of wts cluster, you don't need a boost fooler until you get higher numbers of boost, I assume 30+ but I hit that without issue, and I know a few guys who swear by the hpx, I still have no experience on my truck
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 12 Old 05-12-2013, 03:36 PM
leojr's Avatar
Quoted: 4 Post(s)
My switch is held to the left side of my brake controller with a tie wrap. Did this as a temp location but don't see it being moved in the foreseeable future.
I set my tunes in a sequence that make sense to me. Left to right, position 1 to 6: Stock, High idle, Drive thru, Daily hot, Really hot, No run. I never run Really hot as my truck is home stock so I run on Daily most of the time. One click left and I always know where I am at. Daily to Drivethru is obvious, Drivethru to High idle is obvious, High idle to Stock is obvious.
Denton, TX
I envy those that know exactly which modification to make and in the most logical of sequences. But not enough to trade for my meanderings and misfires.
1996 F250 crew cab/short bed, 4x4, auto PSD, 6637 air filter, interior grab handles, stainless window vents, remote door locks work with engine running mod.
leojr is offline
post #4 of 12 Old 05-12-2013, 04:17 PM
I would skip the muffler and just straight pipe (Personal preference)
For mounting I have it's mounted by my 4x4 switch .. I also use the BDS Switch Plate for $15 I figured it was worth it.
2002 F-350 7.3 ex-cab short bed Beans 6 Pos
6 inch lift, 35,s, 4 Inch Turbo Back, 6637 intake
Foil delete, 05 harley front end, 08 Tailights
Tinted cab lights, and this and that and this
Z-STROKE is offline
post #5 of 12 Old 05-12-2013, 04:56 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
From right to left my tunes are stock, hi idle, light tow, heavy tow, race and extreme, I do everything in extreme, unless it's cold then hi idle
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 12 Old 05-12-2013, 06:33 PM Thread Starter
Why don't you like the muffler? Sound? Is it louder or have more throat? I don't have one to hear so I can't go by that.
YJSONLY is offline
post #7 of 12 Old 05-12-2013, 06:37 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
It's really quiet compared to straight pipe, the turbo alone muffles the sound as is, but with a muffler you also don't get that amazing whistle lol
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 12 Old 05-13-2013, 08:27 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Straight Pipe front to back. Under heavy accel the exhaust sounds like a gasser big block. Get gauges.
Back side:
Straight piped (click picture):
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #9 of 12 Old 05-13-2013, 11:01 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Click no work on my iPhone
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 12 Old 05-13-2013, 11:22 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Stupid Photobucket! When I click from my phone it opens a new tab and takes me to the mobile photobucket site that requires logins and crap. You have to click "full site" at the bottom and let it load. Don't close the full photobucket tab but go back to the ORG tab with the link above and click again. Then it will open from a iPhone
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
