Spacing out rear wheels ... - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-12-2013, 05:53 AM Thread Starter
ChiefRocka's Avatar
Anyone here run a billet spacer adapter ??
It annoys me how bad the rear wheels are tuck'd in compared to front...(almost 3")
We run spacers adapter here on muscle cars and such to correct wheel spacing issues...some with high torque numbers.
Product is a billet piece, and made guaranteed to last.
I can get an 8 lug, 9/16" 3" stud set built for a decent price ...
Thoughts ?
John
2002 F-250, CCSB, 4" Exhaust, Stock otherwise
ChiefRocka is offline
post #2 of 4 Old 05-12-2013, 08:46 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
A few guys run them, but the general consences was not to tow with them, if ya like a couple guy did a rear axle swap drilled hubs and e series rotors Kause the 10.50 is about the same width as the d60
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 4 Old 05-12-2013, 10:24 AM
7.3 on 40s's Avatar
If this helps at all, i recently spaced out my rear wheels 2 1/4 inch to even up my wheel track. I used 2 inch all steel arrowcraft spacers and 1/4 inch aluminum spacer between drum and arrowcraft spacer. Towed about 1k miles and just the other day removed and inspected spacers while replacing wheel seals and everything looks 100%. Also running 40 inch mud tires. All lugs were still tight when removing.
97 F350 XLT CC LB 4x4 7.3psd 5spd White/Tan
-Straight Piped
-6637 Intake
-8in. Lift
-Welds w/40in. Rockers
-Warn hubs
-LSD w/4.56 gears
-Leather bucket seats
-Rhino lined
7.3 on 40s is offline
post #4 of 4 Old 05-12-2013, 05:53 PM Thread Starter
ChiefRocka's Avatar
Thanks guys ....
John
