dana 60
dana 60 front end I know they came off F-350's but what years can I grab from
Depends on your skills!
![]() For a bolt up replacement, look for 1986-1997.
Prior to 1991.5 they were kingpin knuckles vs balljoints. Also you need to find a ford because the are drivers side drop vs passenger side for dodge and chevy. 1992 to 1995 should be a direct bolt up. Not sure about 96-98. 2000 and newer are metric lug pattern.
You can use any from '80-'97. The earlier ones will be fine if you get it complete with brakes and hubs. If not, you may have to do some searching and trial and error fitting. They all will bolt right in. SD 60's will not work without major modification. Pre '80 60's are hard to find and will cost a mint and take some modification, so don't bother.
well I thought I scored a local junk yard said he had 5 dana 60 front ends with 4.10s he said he would give one to me for 350 bucks with 140k on them and 100 trade in for my IFS so I raced down there and there were dana 60 rear end what a doofus
