I am new to this site. I just drug a 96 out of field not running and am trying to put it back into shape. It is running now, but with the 4:10 gears the fuel mileage sucks. I also bought a 2001 e350 powerstroke cargo van with bad transmission. My question is will the 3:55 rear end out of the cargo van be able to be put into my 96 f350 truck? I have always been a cummins man so any input anyone could give me on any other ideas would be great. Thanks
I am not sure what axle is in the van. There for I can not say if the swap would work. How ever since your truck is 4wheel drive you would have to swap the front gears as well.
I'm not sure with the vans, but frame width on the OBS is 38" and on SD trucks 34". Vans also have different wheels from the trucks. The lug pattern is most likely different. I haven't worked on any vans, so I'm not 100% sure, but if it were a '01 truck rear, it would be way off and you would have to do some work to get it to fit.
i am only getting 12 or 13 with the 4:10 gears. i bought a 95 f250 2wd for parts today with 3:55 gears. Is there anything special i need to do when swapping the rear ends? I don't want to do much to the truck. change gears, 4" exhaust, and air intake. Any other diy mods or secrets?
there should be a metal tag on one of the bolts on the cover of the rear end. The tag should tell you or write down the numbers off the tag and call your local ford garage and they will tell you. i have heard from some guys that there is something you should do with the wastegate on these trucks. what should i do?
yes, i am looking into wastegate delete. i heard guys talking about plugging hose and others talking about adding a piece of tubing and poking holes in line. i not really sure.
Here is some good info on dana spicer axles. Librarian
Also here is a pic of an axle and where to find all the info. If you Run the BOM number that will tell you everything about the axle:thumb:
[URL="
The ring gears should be the same or interchangeable. That is if they are both 10.25 or 10.50. You cant interchange between the sizes.
Generally on the 99 newer truck and van a 250 has 10.25" and a 350 has 10.50"
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
266.2K members
Since 2005
