big project coming on. - Ford Powerstroke Diesel Forum
Old 02-27-2008, 08:22 PM
hey guys I got a big project coming up well not as big as what maintain is doing. but I am for one replacing the oil pan gasket so I am good there. but also the owner before me installed an add a leaf and got some camber adjustment for the upper ball joints so it's still 2 degrees positive on the driver side. so I am getting a axle pivot drop bracket and then replacing the bushings is there any advice any of you can give me beside go and buy a dana 60
Old 02-28-2008, 03:21 AM
Gun Nut
Let me give this a bump to see if anyone can give you any advice.
Old 02-28-2008, 04:08 AM
BIG TRUCK, SMALL DRIVER
The springs play a major role in the TTB alignment. If they sag too much, you may be better off to get new ones. I do recommend a 60, though. Good luck!
Old 02-28-2008, 06:03 AM
hmm I see well the cheapest dana have have found with 4.10s is 1,200 bucks so far
Old 02-28-2008, 06:14 AM
COLLEGE KID
Send a message via AIM to lifewitlooie
at the junk yard? i put my lift on but never mesed with the bushings or any of the other stuff besides the drop down bracket. i wish i had a dana 60 but the IFS aint so bad. its just ugly
Old 02-28-2008, 06:44 AM
That is about the going rate on a D60. Try to find a high pinion as well. They are a little harder to come by but worth it if you ever lift your truck. I am looking ito doing a D60 swap or even a complete set of SD axles under mine one of these days.
Old 02-28-2008, 07:00 AM
Desert Shield/Storm Vet
Yeah they are high. Im looking for a front Dana 60 right now and that is the going rate like NovaJoe said. Also as long as its a Ford Dana 60 it will be high pinion
