help on a 1995 - Ford Powerstroke Diesel Forum
Old 02-27-2008, 06:29 PM
help on a 1995
just bought a 1995 f350 ps standard cab 4x4 193000 when i started it up white smoke was present small amount,at idle it was there but not much. the guy said the truck never gets warm? new injectors, water pump,thermostat.you guys got any ideas as whats going on. no mods to the truck ever bone stock. any ideas would be great.
Old 02-27-2008, 06:48 PM
no body out there tonite?
Old 02-27-2008, 06:54 PM
never gets warm...or never gets warm at idle??
Old 02-27-2008, 07:06 PM
Never gets warm can cover a lot of ground.. never gets warm as in the guage doesn't move? Never gets warm as in no heat out of the heater? Radiator cold after running for a while? Runs a little "off" like it's freshly started?
Old 02-27-2008, 07:07 PM
are you SURE the tstat isnt stuck open??
Old 02-27-2008, 07:12 PM
Send a message via AIM to FiberglassEater
my 97 always smokes white in the morning .... but then again i think i got some bad glowplugs.....
Old 02-27-2008, 07:17 PM
sounds like a stuck thermo but my truck smokes a little in the morning
Old 02-28-2008, 05:10 AM
60 degrees outside ran for 15 mins just barely off cold.
Old 02-28-2008, 05:11 AM
barely moves off cold on gauge and there is hot air from heater.has a good idle
Old 02-28-2008, 05:15 AM
didnt get warm at idle but hot air coming from heater vents
