New Turbo - Ford Powerstroke Diesel Forum
Old 02-26-2008, 09:12 PM
New Turbo
I was woundering what it would take to put a newer turbo on my truck? What would I need to do to put a 99 turbo on my truck or maybe a turbo from a 6.0. What would be the best? What issues would i face? how much power would I gain from each?
Thanks!
Old 02-27-2008, 02:07 PM
Send a message via AIM to FiberglassEater
im wondering myself
Old 02-27-2008, 02:14 PM
BIG TRUCK, SMALL DRIVER
For a SD turbo, you have to use the SD up pipes, Y pipe, turbo pedestal, etc. I'm not sure what you would have to do to get the downpipe to work. The rest should be pretty easy. I don't see any gain from running a SD turbo, though. The 6.0 turbo would be neat just for the variable vain, but I wouldn't want to imagine all the work it would take to get it on an OBS. The turbo you have is good for all the power you can make with your stock injectors. You do have a couple aftermarket choices, like the H2 and D66.
You could use a 1.0 turbine housing to get quicker spool. This is a great option on our trucks.
Old 02-27-2008, 02:24 PM
International Threat
Forget the SD turbo's and buy an aftermarket that is bolt on.
H2E or D66.
You'll want an intercooler as well.
Old 02-27-2008, 07:27 PM
I was thinking a turbo from an 03 6.0 seeing what it would take for that?? what does on intercooler do for me? I dont have one?
Old 02-29-2008, 09:03 AM
i was told by a diesel shop that you cant put a ball bearing turbo on an obs cause theres not enough room
Old 02-29-2008, 09:09 AM
Almostdunfukinwidit
I dont think its possible to put a 6.0 VGT turbo on a 7.3
Old 02-29-2008, 09:26 AM
Desert Shield/Storm Vet
Actually Dave it is possible there was someone in California that did it VanAkinbrothers or somthing like that. I actually saw a video of a truck where they were testing and just had to get the programming right and they were going to market it. Not sure what ever happened
Old 02-29-2008, 09:31 AM
Almostdunfukinwidit
I stand corrected then Thanks man
Old 02-29-2008, 09:33 AM
I will see what I can find for info. They were on the diesel stop maybe they had issues as I never heard much after they were testing it.
