Need help with power steering flush..m - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-07-2013, 10:58 AM Thread Starter
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
My cousin needs with his power steering flush. I have an 06 and I know his 97 is different. With his, what are his options on replacing the fluid? Remove the return line off of the bottle? Or pump? Anyone snap a picture of the line that has to be removed? And any synthetic ATF would work merc/dex?
MrOneEyedBoh is offline
post #2 of 10 Old 05-07-2013, 12:18 PM
boozinag's Avatar
any ATF that is rated for a ford should be fine.
Gerry
'97 CCSB f-250 4x4 auto, 6pos chip w/ canned tunes, AFE intake, 4 in exhaust, 3in dp, 3.55 gears,
Dana 60 rebuilt and waiting to be installed
184k
boozinag is offline
post #3 of 10 Old 05-07-2013, 12:30 PM
ZMANN's Avatar
Quoted: 1916 Post(s)
pull the return line on the side of the hydroboost
plug the end going to the reservoir
then hook a few feet of hose to the hydro boost nipple ( like 3/8's IIRC)
then or before LOL
wet the concrete and add some soap or jack the front tires up
start truck
and turn lock to lock and push down on brakes multiple times while also filling
this is easier with 2 folks but one isn't bad since it won't dispel fluid unless your giving steering or brake input so you can leave truck running and refill
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #4 of 10 Old 05-07-2013, 12:30 PM
ZMANN's Avatar
Ahh carp I thought you were asking about the 06
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #5 of 10 Old 05-07-2013, 12:42 PM Thread Starter
Quoted: 13 Post(s)
Yeah zmann lol. I was like wait sounds like mine haha
post #6 of 10 Old 05-07-2013, 01:34 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
obs don't have hydroboost aside from the f-superduty
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 10 Old 05-07-2013, 03:30 PM
the baconator
terryknight's Avatar
Quoted: 153 Post(s)
there is a return line on the bottom of the reservoir pull it and do as you normally would.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #8 of 10 Old 05-07-2013, 04:07 PM
JD3020's Avatar
The return line is on the bottom of the reservior, so won't pulling it off dump all the fluid out?
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 216k miles: FFD 250/200%'s, stock turbo, built trans, e-fuel, Swamps IDM, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube. Built and tuned by me
97 F-250 ECSB project truck:250/2's, Gen 3, S468, SD axles, studs/springs, ZF-6
JD3020 is offline
post #9 of 10 Old 05-07-2013, 04:12 PM
the baconator
Quoted: 153 Post(s)
you're right brain fart
post #10 of 10 Old 05-07-2013, 04:29 PM
JD3020's Avatar
What you could do is get a rubber boot of some sorts and slap on there to plug that nipple
Jimmy
JD3020 is offline
