EBP Tube and sensor - Ford Powerstroke Diesel Forum
post #1 of 13 Old 02-26-2008, 07:27 AM Thread Starter
EBP Tube and sensor
I took the ebps off the tubing and it was clean as a pin so I put it back on thinking it was in good shape. Now I`m wondering since the sensor is so clean if the tubing is stopped up. Should I be getting at least signs of a little soot? TIA.
97 F-350, 7.3 psd, xlt, limited edition, obs, dually, E40d at, 410 r axle, reg. cab, 8ft bed, 145000 miles, DIY Tymar intake (napa filter) CCV mod. fpr bb mod, HPX crossover pipe, SS Bully steps, Reese Fifth wheel hitch, CB Radio, 3" DP /4" back w/cat delete and 4" flow-thru muffler w/5" tip.
Triflex is offline
post #2 of 13 Old 02-26-2008, 07:36 AM
spuds99's Avatar
tube
You will find that it is not that hard to take off if you can get it broke loose of the exhaust side. After that, even if you are a novice, it is worth the 15-20
min of taking it off and checking it out.
I cleaned my sensor and tube n got a 3MPG INCREASE!!
Cowboy up!
99.5 PSD XLT Lariat
Dual Leather Buckets
EBPV Delete
Wastegate Delete
DIY Intake
6spd W\ PacBrake
Edge W\ Attitude
4" TB SS Exhaust
Kitty, Muffler Delete
Dual 6" Stacks
SXT 33'S
Mods Comin'
Lift kit
Banks Compressor Wheel--HERE!!!
spuds99 is offline
post #3 of 13 Old 02-26-2008, 07:40 AM Thread Starter
Wow! 3mpg. I agree, I will take it off just to be sure. Thanks.
Triflex is offline
post #4 of 13 Old 02-26-2008, 12:49 PM
Question
To clean the sensor you have to desintall it? and how did you clean it?
CELAYORK is offline
post #5 of 13 Old 02-26-2008, 12:53 PM
Desert Shield/Storm Vet
vitalidle's Avatar
Here you go Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #6 of 13 Old 02-26-2008, 01:13 PM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
I just pulled mine and cleaned it. It was easy to remove, but a pain to get the soot out of the tube. I did have a lot of build up. Hope it helps the fuel mileage. I replaced the ICP also. An extra 3 MPG would be great.
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #7 of 13 Old 02-26-2008, 01:20 PM
vitalidle's Avatar
Also if you gut or unplug your ebpv then you don't have to worry about cleaning the tube anymore
Auto 93,000 miles
DP Tuner F5
post #8 of 13 Old 02-26-2008, 01:24 PM
Arrow
Thanks a lot, thats a good write up.
CELAYORK is offline
post #9 of 13 Old 02-26-2008, 01:26 PM
powerstruck's Avatar
would the ebps eliminator that DFUSER sells get rid of these problems?
2003 F-250 4WD EXT CAB
EBPV delete
turbonetics BB turbo
4" mbrp straight pipe turbo back
volant cold air intake
ts-6 chip
egt, boost, fuel pres. guages C2
aih delete
fuel regulator shim kit
hpx-over
zoodad
amsoil by-pass oil filter
coolant filter
4" superlift
315/70/17 BFG a/t
bilstein shocks 5100
*southbend clutch next on the list
powerstruck is offline
post #10 of 13 Old 02-26-2008, 01:26 PM
vitalidle's Avatar
You bet! He has lots of good info on his site
Auto 93,000 miles
DP Tuner F5
