TRUCK WILL NOT ALLOW ME TO SHIFT!
I have a 97 f-super duty. i pull on the lever and it will not allow me to shift into gear, i took the plastics off the steering column and noticed when i pulled on the lever in didnt depress the large pin in the middle of the sleeve, the whole sleeve moved back with the lever. i noticed two screw down brackets that seemed to hold it in place but nothing else i could see that would hold the sleeve from moving back and forth. i tried holding the sleeve in place and it still wont allow me to shift, which is leading me to think that something caused a break by not allowing the pin to depress it......any suggestions would be greatly appreciated its stuck out on the street in front of my house i gotta get it off the road.
does it have the brake lock where you have to push the brake down to get it out of park. if so check your fuses my brother in law had a crown vic that did that fuse was blown. good luck
Good luck with it. I wish I could help.
thank you, it was in fact a fuse under the hood....i checked them yesterday but i missed it! thanks again
Didnt know if it had it my 96 is a 5 speed. Good it was an easy fix
