Beans e fuel. Help - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-04-2013, 08:44 PM Thread Starter
Beans e fuel. Help
My brother received his e fuel kit from beans and it is a well made kit. We installed without problems but when we wired up the pump ther was nothing the pump wouldnt turn on or prime. He I needs the trck for work on monday please help. I have taken photos to help.
Pic #1
The start of the wiring harness. This is how I wired it.
Also I don't know how to wire the oil pressure sensor in I tried but don't know if it is right. I put the white wire supplied in the harness on the sensor and then put another wire in the fuse box in a 10 amp fuse. Where does everybody else wire the oil pressure in at? Please help
fowllivin is offline
post #2 of 4 Old 05-05-2013, 11:14 AM Thread Starter
So I got everything working pump and the oil pressure switch but now I can't get truck to start. The pump turns on fuel pressure builds to 60 psi but it won't crank. I have checked all the fuses and disconnected the return line at the selector valve and tried to start it and fuel pours out. I also disconnected the fitting at the drivers side rear head and fuel comes out. I checked the wires in the valley and still nothin. Any suggestions
post #3 of 4 Old 05-05-2013, 02:41 PM Thread Starter
Re: Beans e fuel. Help!
I figured it out I didn't reuse the old harness from the fuel bowl. The hpop was not working because I didn't have the electrical connected. So I just cut and capped the wired that I didn't need from the old fuel heater and plugged it back in and she fired up instantly with no problems.
post #4 of 4 Old 05-05-2013, 02:43 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Glad you got it figured out
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
