Preventative electrical maintenance - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-04-2013, 07:18 PM Thread Starter
vandy's Avatar
Something that's been on my mind. It seems there are several sensors that will give you a bad day if they just go out on you.
So that said in my case with a 276k mile rig and not having any heads up on the maintenance done to her. What would/should i go ahead and replace or at the least keep a spare in the glove box.
vandy is offline
post #2 of 7 Old 05-04-2013, 08:19 PM
dazed01's Avatar
Not sure about the sensors, but spraying deoxit on any connector you disconnect is a good pm policy.
Gun control is like trying to reduce drunk driving by making it tougher for sober people to own cars.
dazed01 is offline
post #3 of 7 Old 05-04-2013, 09:05 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
CPs, idm, PCM, fuses, and bulbs
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 7 Old 05-05-2013, 07:20 AM
Quoted: 43 Post(s)
^^^^^ +1; including maxifuses. And a cheap multi-meter.
madpogue is offline
post #5 of 7 Old 05-05-2013, 12:36 PM Thread Starter
vandy's Avatar
How bout a ipr? Hoe often do they go bad?
vandy is offline
post #6 of 7 Old 05-05-2013, 12:58 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Never had one fail, so couldn't tell ya, actually only thing I've ever had to replace is the CPs, but ipr usually goes from being oily, at least that's how they end up in the problem forum
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 7 Old 05-05-2013, 01:42 PM
jesilvas's Avatar
Quoted: 2 Post(s)
ICP sensor.
4R100, 2wd
330,000 + miles
jesilvas is offline
