Ac compressor seized - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-03-2013, 10:56 PM Thread Starter
I have a 97 f350 and my compressor is seized and smoke was coming out. My question is I now that I need to change my orfice tube, accumulator and compressor. Do I need to take this to a shop to have the coolant drained, flushed and refilled or can I just do it in the driveway without Any special equipment. Thanks in advance.
fowllivin is offline
post #2 of 5 Old 05-05-2013, 04:57 PM
mkeith54's Avatar
If there is pressure left in the A/C system than you should go have the refrigerant recovered. To recharge you'll have to vacuum down the system and then leak check it, finally add the new R-134a. Unless you have the specialty tools available take it to someone and have it done.
Mike Keith
New Florence Mo
1996 F-250 ECSB, 6-pos/ts chip/ Tymar intake
Pyro, boost, and tranny gauges
mkeith54 is offline
post #3 of 5 Old 05-05-2013, 05:35 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
It's illegalle to vent it in the aptmosphere, so if your gonna do that all your self at least have it vacuumed down at the shop
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 5 Old 05-05-2013, 05:57 PM
Send a message via Skype™ to bwmtnbiker
Personally I would take it to the shop. I had all the tight tools to do mine and did everything right and it blew up 2 weeks later. Just take it in and let them worry about it. It costs more but its on them if its not right.
-Brian
2003 F-250 6.0L - Lariat King Ranch
-300k+ miles and still strong
Current Mods
-6.5" Pro-Comp lift
-Edge CTS
-SCT X3 (Tuned by Vivian
-4" Turbo Back Silverline Exhaust, 5"tip
-Blue Spring Mod
-Sinister Coolant Filter
-Oil Cooler
-Sinister EGR Delete
-OEM Cab Lights
Wants/Soon
-ARP Studs
-MTW Stage 1 or Hybrid
-6.4 Banjo Bolts?
bwmtnbiker is offline
post #5 of 5 Old 05-05-2013, 06:34 PM Thread Starter
Thanks I think I will have to take it in.
