FG PSI
Does the fuel pressure remain constant. If I get 65 PSI at the shreader valve at idle what can I expect to get at 2000 RPM? Do I need to install the FPG inside the truck?
need gauge inside to know exact but it does drop under load
Theoretically then at idle (65psi) should be max if it drops under load and the under hood guage should be ok. Thanks I appreciate it.
on mine at free way speed I see about about 72 psi then when I floor it it drops to about 45 then when I let off it jumps up to 80 . hope that helps
thanks, it helps a lot.
where do hook the pressure gauge up on the OBS 7.3?
I hooked mine with the valve that reliefs fuel pressure i can will show you all
yeah if you had some pics that be great i tried to figure it out but wasnt sure where exactly to put it
this is were I hooked mine up on my obs if i am wrong now would be the time to tell me
thats where i was think of, where did you get a electric FP gauge and how much did it cost ya?
