couple of questions about rsk - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-02-2013, 02:12 PM Thread Starter
ryandamo's Avatar
going to be re doing the suspension on my truck over the summer using reverse shackle, and superduty springs.
First question, can i just use obs spring busings on the superduty springs so i can use easier to find bolts?
SEcond question is anyone running fisher minute mount with a rsk?
Third, what are clean dually beds going for these days
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
post #2 of 4 Old 05-02-2013, 02:32 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Beds depend greatly on location, here is anywhere from $300-1000,
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 4 Old 05-02-2013, 08:02 PM
JSchuricht's Avatar
The bolts aren't that hard to come by and they are only needed for the rear springs for the front mount. IIRC they were $6-7 ea from Ford plus another $6-7 for the nuts, bushings would be the same if not more plus it's easier to hold a drill up to the hanger than it is to hold a spring on the press.
N806967-S426 front bolt
N806967-S426 front nut
JSchuricht is offline
post #4 of 4 Old 05-08-2013, 02:49 PM Thread Starter
ryandamo's Avatar
thanks for part numbers
ryandamo is offline
