Diff swap - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-01-2013, 06:25 PM Thread Starter
Ryedogg7.3's Avatar
Diff swap
I'm looking at swapping a one ton rear diff into my 96 f250. I'm wondering if my drive shaft will be the right length or will I need to shorten it. Reason I swapping diffs to have 4.10 gears
96 f-250 solid axel, afe cold air, 4"straight pipe, 3 stage edge chip, 90horse sticks, banks technicooler, 6" lift , 35 trail grappler
Ryedogg7.3 is offline
post #2 of 11 Old 05-01-2013, 06:33 PM
boozinag's Avatar
You can either swap the ring gears and pinion, or the entire axle. If you just swap the gears you shouldn't need to change your driveshaft length. If you have 4x4 you need to make sure the gears match.
Gerry
'97 CCSB f-250 4x4 auto, 6pos chip w/ canned tunes, AFE intake, 4 in exhaust, 3in dp, 3.55 gears,
Dana 60 rebuilt and waiting to be installed
184k
boozinag is offline
post #3 of 11 Old 05-02-2013, 05:01 PM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
rears from the srw 250 and 350 trucks are the same, all sterling 10.25 axles, though there are some slight variations between the earlier 86ish-91 ish and later 92 ish - 97ish axles
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #4 of 11 Old 05-02-2013, 05:11 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
You already have a 1 ton rear dif
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 11 Old 05-02-2013, 06:06 PM Thread Starter
Ryedogg7.3's Avatar
Ya I already have a king pin 60 and a 70 rear. the rear is from a 93 f-350 and the front is a 91 I believe
post #6 of 11 Old 05-02-2013, 06:09 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
If your rear is from a 93 it's still a sterling 10.25
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 11 Old 05-02-2013, 06:11 PM Thread Starter
Ryedogg7.3's Avatar
So straight bolt in no messin with drive shaft length
post #8 of 11 Old 05-02-2013, 06:13 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Exactly, but you could just swap carriers and be done, no heavy axle to move
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 11 Old 05-02-2013, 06:30 PM
the baconator
Quoted: 141 Post(s)
swapping carriers to me is a bigger PITA than swapping axles, because you will have to set up the gear correctly and replace bearings and things and do it twice whereas swapping axles should be much quicker, at least for me
post #10 of 11 Old 05-02-2013, 07:02 PM
boozinag's Avatar
I agree. They are already set up the way the are, I wouldn't mess with them. Swap the entire axle if you got one.
Gerry
184k
boozinag is offline
