Boost Guage? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-22-2008, 11:52 AM Thread Starter
Boost Guage?
I am installing a fuel preassure guage,(under hood, shraeder valve mod), and these two, an EGT ga. and tranny temp ga. on pillar pod. My question is since all I do is tow a 12000 lb T Trl.,no racing etc. do I also need a boost guage?
97 F-350, 7.3 psd, xlt, limited edition, obs, dually, E40d at, 410 r axle, reg. cab, 8ft bed, 145000 miles, DIY Tymar intake (napa filter) CCV mod. fpr bb mod, HPX crossover pipe, SS Bully steps, Reese Fifth wheel hitch, CB Radio, 3" DP /4" back w/cat delete and 4" flow-thru muffler w/5" tip.
Triflex is offline
post #2 of 10 Old 02-22-2008, 11:53 AM
97bluestroker's Avatar
Send a message via AIM to 97bluestroker
in my opinion it's something nice to have... one more thing that you can monitor on your rig. i like to know what my truck is doing LOL
'97 F250 HD PSD, 4x4, Auto, Ext Cab, LB, 4" Lift, Tint, 80/120 hp DP Tuner, Straight Piped, AFE Stage 2 Air Intake w/ Pro-Guard 7, Aftermarket Intercooler, SpecRite Dual Disk Torque Converter, Pumped Up Tranny w/ Transgo Kit, MagHytec Deep Tranny Pan, Pyro, Boost and Tranny Temp Autometer Gauges, Pro Comp Adjustable Shocks, 305/70/16 BFG Mud Terrains on Weld Rims, Spray on Bedliner, Flip Down DVD Player
97bluestroker is offline
post #3 of 10 Old 02-22-2008, 05:36 PM Thread Starter
Good thinking. thanks
Triflex is offline
post #4 of 10 Old 02-22-2008, 06:30 PM Thread Starter
Will any liquid filled preassure guage work? Grainger has one, a 100psi for like 13 bucks. Does that sound right considering the prices I see on other sites.
Triflex is offline
post #5 of 10 Old 02-22-2008, 07:10 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
100 Psi for a boost guage? nah, dont go that high, you wont ever hardly see the needle move. Go with a autometer 30 PSI guage or similar brand. DiProcal, Stewart warner, ect....
You truck is only gonna see 30 PSI max with a tuner. any more than 28 PSI and the turbo is on borrowed time.
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #6 of 10 Old 02-22-2008, 10:33 PM
Rantheman's Avatar
I think he was reffering to the fuel pressure guage.
1995 Ford F250 4X4 Sup cap Long bed off white
7.3L Powerstroke, 5 speed manual
Mods Stancor GPR, Diamond eye 3" DP, Diamond Eye 4" Exhaust, AFE Stage II Intake,3" plenum setup,Swamps IDM,Eletric Fuel System,Adrenaline HPOP,stage I sticks, ts 6 pos,
Banks 5" Tips, Leveling Kit,Dana 60 Swap, AutoMeter Boost, Pyro, Fuel Pressure
30% Windows,
Rantheman is offline
post #7 of 10 Old 02-23-2008, 06:15 AM Thread Starter
You are correct. we were discussing a fuel preasure guage for the fpr.
Triflex is offline
post #8 of 10 Old 02-23-2008, 06:23 AM
Lord Tauk's Avatar
Here's an alternative;
Liquid Filled Pressure Gauge
Anything rated for like oils and such from an industrial supplier will work too, it'll probably a better gauge in construction and accuracy if that matters. I'd get a gauge from Grainger.
Rick got himself a really nice one for under the hood, I like it more than I like the Marshall one ITP sells.
Lord Tauk is offline
post #9 of 10 Old 02-23-2008, 07:57 AM
Doesn't Even Care
Quoted: 69 Post(s)
Oops, sorry,I just read the black bold typeing above and saw boost guage. I am also very sick, so that may have added to my confusion. Sorry fellas.....
Nick
"The Mistress"
post #10 of 10 Old 02-23-2008, 02:58 PM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
I got mine from an industrial plumbing supply house. 200psi
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
