My 3" Diamond Eye DP... - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-30-2013, 10:39 PM Thread Starter
...was installed earlier this month and I finally got the chance to put it to the test.
Pulling a 24 ft Travel Trailer up a 14% grade, about a mile long:
The engine noise is DEFINITELY more noticeable now...especially during and after a hard pull; it will make some real growling sounds! The transmission seems to down-shift easier than before, and it really feels as if there are a few more horses present.
My top speed was about 40 MPH, but I didn't want to push it. I held the RPM's at around 2200 and she chugged along just fine. Engine temp increased briefly during the climb but dropped as soon as we levelled off.
VERY pleased with the results of this mod.
All in all, I think this was THE BEST upgrade I've made so far, and would highly recommend it to anyone sitting on the fence.
The pipe is not that expensive and if you're handy with the tools, you can do it yourself - I didn't.
One thing to think about is that the pipe runs REALLY close to the transmission, so what I did was to wrap some 3" fiberglass pipe insulation where it passes by, and tie-wired it in place.
97 F250 PSD...6637 Filter upgrade...3" Diamond Eye DP...DFuser EBPV eliminator...Improved "Blue" CPS...
Qwazert is offline
post #2 of 6 Old 05-01-2013, 07:37 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Glad your enjoying it, down shifting may have helped you a bit up that hill, and I hope you have gauges hauling like that and chugging
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 6 Old 05-01-2013, 09:50 PM Thread Starter
I have no gauges, other than those installed at the factory.
With regards to the hill climb...I could have gone faster, but I chose to hold things at 40 MPH/2200 RPM.
This particular hill has a reputation for eating transmissions and overheating engines, because it is so steep. Here is a graph of the highway:
http://www.th.gov.bc.ca/popular-topi...de-profile.pdf
...in 6 miles, you climb over 1500 feet! I don't know how they get 8.5% grade on that...I'm quite sure the sign said 14%.
Qwazert is offline
post #4 of 6 Old 05-01-2013, 10:04 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
That's a pretty damn steep hill, and gauges will let you know what temps your running and may help to save that trans in the future
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 6 Old 05-02-2013, 03:24 PM
ChiefRocka's Avatar
What guage make is everyone running ... Autometer ??
John
2002 F-250, CCSB, 4" Exhaust, Stock otherwise
ChiefRocka is offline
post #6 of 6 Old 05-02-2013, 03:39 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I run auto meter and aero force scangauge
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
