Turbo Cleaning? - Ford Powerstroke Diesel Forum
post #1 of 20 Old 04-30-2013, 07:24 PM Thread Starter
KS_
Quoted: 22 Post(s)
Turbo Cleaning?
My truck has been ran for a good 550k without the turbo being touched. I know it has to be dirty as all get out. I just don't know if it should be cleaned and if so how and what with..
  • Kaleb - 97 F-250. 1.0 housing, WW2, 3 inch dp to 3.5 straight pipe, TS 6POS chip, Riffraff 6637 Intake, 4" Rough Country Suspension Lift and 33"s.
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
KS_ is offline
post #2 of 20 Old 04-30-2013, 10:09 PM
Justin@DP-Tuner's Avatar
Quoted: 61 Post(s)
Pull the intake off and look at the wheel. What condition is it in? Also, reach your hand in there and try to move the shaft. Does it move at all?
If the wheel looks good, and there is minimal shaft play, then there is no need to do anything to it unless you want to. A little bit of up and down play is normal(as long as it isn't hitting the housing), but any in and out play is no good.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #3 of 20 Old 05-01-2013, 04:49 AM Thread Starter
KS_
Quoted: 22 Post(s)
Thanks, Ill check that out tonight. I just wasn't sure if I didnt clean it if it'd get corroded or something
KS_ is offline
post #4 of 20 Old 05-01-2013, 05:01 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Wow 550k without being cleaned!!!! Heck the dirt might be the thing that is holdin it together. I guess I gotta say congrats on the 550k!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 20 Old 05-01-2013, 05:07 AM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Yea I agree! 550k is great, my 96 7.3l only has 131k on it.. Still ways behind ya.
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #6 of 20 Old 05-01-2013, 05:15 AM
PSDTV21's Avatar
I think thats the highest mile obs Ive heard of. Nice!
-Tyler
1994.5
Efuel, Valair 500hp, D60, Hydra w/PHP tunes
PSDTV21 is offline
post #7 of 20 Old 05-01-2013, 07:18 AM
bucwheat's Avatar
My 97 only has 285,000,hope I get to 550.
1997 F-350 CC Dually
Power Hungry performance chip. DIY air intake ,4" Diamond Eye exhaust, Trans temp gauge,Pyrometer gauge
10,000 Lb. Warn Winch, 1 million candle power auxilary lights,black heavy diamond plate bumper/brushguard
bucwheat is offline
post #8 of 20 Old 05-01-2013, 07:43 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I'm over that combined but not in a single rig lol
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #9 of 20 Old 05-01-2013, 08:26 AM
TANPOWERSMOKER's Avatar
WOW U must drive a lot! what do u do with your rig to rack on that many miles?
-Brenden-
Theres Nothing Like A Good Cigar
95' F-250 7.3 EXTRACAB 4x4 LONGBED ZF5 238k
M.B.R.P down pipe,4" pipe to 5" turnouts, 6637 INTAKE, FPR SHIM, FP gauge, P.H.P. CHIP, Dana 60 swap, ccv mod, Issapro A-Piller Gauges, Aero force obd2 gauge, Rear 32gal bronco tank, 35" coopers(with no lift
), steel flatbed, home made 7ft track bars,Zf5 swap and valair cluch!!!
(I love Slaming beers...Oh, i mean gears)
SOON TO COME: Rosewood stage 1.5
TANPOWERSMOKER is offline
post #10 of 20 Old 05-01-2013, 08:28 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Travel lol
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
