Turbo o ring? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-30-2013, 04:34 PM Thread Starter
Turbo o ring?
I just now realized i was supposed to have an o ring from the turbo to y pipe, and i do not have on, just the clamp. I noticed this when i took the y pipe off to drill and tap for boost gauge. How crucial is it to have that o ring? Where do i get a new one at?
95 f250 powerstroke, zf5 with solid flywheel conversion, 3 inch downpipe to four inch diamond eye stainless steel exhaust, riffraff 6637 intake, pyro and boost gauges, and more to come
_95stroke is offline
post #2 of 4 Old 05-01-2013, 08:06 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
It's a F4TZ-9E436-A. About $6 from ford. Crucial? No. Important for boost control? Yes. In a pinch I have used gasket maker to make the seal till my new one came in. If your Ford is giving you trouble getting the part find AutoFair Ford here on the ORG. He sells Ford parts and ships fast!
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 4 Old 05-01-2013, 08:13 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
Originally Posted by BigFuel View Post
It's a F4TZ-9E436-A. About $6 from ford. Crucial? No. Important for boost control? Yes. In a pinch I have used gasket maker to make the seal till my new one came in. If your Ford is giving you trouble getting the part find AutoFair Ford here on the ORG. he sells Ford parts and ships fast!
ALL IS CORRECT! Have it in stock!
2000-7.3L is offline
post #4 of 4 Old 05-02-2013, 08:57 PM Thread Starter
Ok cool. Ill prob order one soon so i can get more psi of boost. I get decent boost as is too. For stock at least lol. I also found it for 3.29 on riff raff. Ill prob just order it from autofair when i do order it.
