FS2500 - Ford Powerstroke Diesel Forum
post #1 of 36 Old 04-30-2013, 04:27 PM Thread Starter
boozinag's Avatar
FS2500
So who here uses the FS2500 system?
How long do you go before oil changes?
Do you feel like it was worth the investment?
Curious to know, I figure that with the way our engines use oil it is probably a sound investment. However, I would like to hear some firsthand experiences.
Gerry
'97 CCSB f-250 4x4 auto, 6pos chip w/ canned tunes, AFE intake, 4 in exhaust, 3in dp, 3.55 gears,
Dana 60 rebuilt and waiting to be installed
184k
boozinag is offline
post #2 of 36 Old 05-01-2013, 05:18 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
got a link.?
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #3 of 36 Old 05-01-2013, 05:47 PM Thread Starter
boozinag's Avatar
http://fs2500.com
Gerry
184k
boozinag is offline
post #4 of 36 Old 05-01-2013, 06:04 PM
hijo202's Avatar
I've had it on mine for about 5 years now. No issues at all. I go 15k miles before filter change (every other oil change). Been told I can go longer on the FS filter change, but, I would rather keep good fresh oil flowing...350k miles and purring right along. Even the recent Blackstone results were very good for the age and miles. Oh, and still original injectors...
'97 F-250, 4x4, Supercab, D60 Swap, Intake, Turbo Back Exhaust, TW 6 pos, IDM Mod, HPX, FS 2500 Oil Bypass, Quadzilla Recon XZT Digital Gauge, RSK w SD springs, 1.0 compressor housing, EBPV delete, modded pedestal, E-fuel with "Tight-wad" regulator mod
hijo202 is offline
post #5 of 36 Old 05-01-2013, 06:39 PM Thread Starter
boozinag's Avatar
So you still do oil change at regular intervals? I have read of guys going up to, and farther than 20k miles before needing an oil change in diesel vehicles with this system. I just was wondering if that was possibly the case with our trucks even with the high pressure injection system.
Gerry
184k
boozinag is offline
post #6 of 36 Old 05-01-2013, 08:29 PM
A friend of mine has been using that same filter set up for years. He had it on his 6.0 and now its on his 6.7. swears up and down its the best.
hithebrakes is offline
post #7 of 36 Old 05-02-2013, 04:12 PM
hijo202's Avatar
I do change around 7500 miles. I do it because I don't drive the truck often, actually 1 oil change lasts over 1 year. So, I think I "stretch" it after reading about how oil that isn't used much can develop "acid" build up and such.
hijo202 is offline
post #8 of 36 Old 05-02-2013, 06:45 PM
ol_Blue97's Avatar
with our injection system u will not see the full benifit from it but it cant hurt. whats the price of one filter, i guess i can check the link
FRANK THE TANK
post #9 of 36 Old 05-02-2013, 07:01 PM Thread Starter
boozinag's Avatar
Even if it doesn't extend periods between oil changes it has to extend engine life by keeping particles out of the injector system and off the cylinder walls.
Gerry
184k
boozinag is offline
post #10 of 36 Old 05-04-2013, 09:00 AM
nra1ifer's Avatar
I put one on my 1995 PSD. VERY easy to install. I'm about 1K miles away from sending my first 5K-mile sample to Blackstone to see how it's looking. I don't plan on going much past 7,500 miles on an oil change, but it'll be based on the analysis results.
nra1ifer
1995 F250 Ext. Cab 7.3L PSD
I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them.
nra1ifer is offline
