1997 F250 XL 7.3 Cruise Control - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-30-2013, 04:07 AM Thread Starter
I have a 1997 F250 7.3 XL. I am wanting to change the steering column and put an XLT column in. It has an automatic trans in it. What do I need to do other than changing the steering column in order to get the cruise control to work? All help is much appreciated. Thanks
jtrader23 is offline
post #2 of 4 Old 04-30-2013, 06:27 AM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
If all you want to do is add the cruise, you don't need to change the column. All you need is the horn pad with cruise. Cheers!
Patrick Feeley is offline
post #3 of 4 Old 04-30-2013, 06:40 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I beleive the master cyl also needs a port on it to function correctly
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 4 Old 04-30-2013, 07:24 AM Thread Starter
I guess I forgot to mention that I want tilt too. Is the wiring all there? What is it that would plug into the Master Cylinder? Would all of that be on the XLT Steering Column? Appreciate the help guys.
