94.5 - 97 Fuel Accumulator - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-29-2013, 10:04 PM Thread Starter
Thumbs up 94.5 - 97 Fuel Accumulator
I have this fuel accumulator. I was told, "While your in there" doing the fuel pump. Turns out, My truck doesn't even have one. The Ford dealer wont take it back. As it stands, I am out 130$.
I am in Southern California, If your local, from San Diego to South LA or Temecula to Riverside, I will trade it out for a new NAPA manual lift pump, they run around 90$.
Saves you 40$ and minimizes my loss. Win/Win.
If your in another state & wanna mail me the pump.
As soon as I get it, I'll mail the accumulator.
Irish95 is offline
post #2 of 10 Old 04-30-2013, 07:16 AM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Just for info: The accumulator, or pulse dampener, is only found on the late 96 and 1997 California model trucks running the split-shot injectors. Cheers!
Patrick Feeley is offline
post #3 of 10 Old 04-30-2013, 07:33 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Where is it at? I've never seen one in mine
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 10 Old 04-30-2013, 08:26 AM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
should be under the turbo attached to the fuel pump
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #5 of 10 Old 04-30-2013, 08:28 AM
Phillipjon's Avatar
Quoted: 76 Post(s)
What is the purpose of it?
Phillipjon is offline
post #6 of 10 Old 04-30-2013, 10:42 AM
Wink
As mentioned they are only for Cali models. Here you are: look here: Cali fuel pump replacement - Page 2 - Ford Truck Enthusiasts Forums
It decreases the pulses of the fuel pump, that its name Dampener.
CELAYORK is offline
post #7 of 10 Old 04-30-2013, 11:03 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
why do only the cali models have it? just weirdness, im only assuming since the cali has a particular spring as well, but why are the non cali models using the cali spring?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 10 Old 04-30-2013, 04:38 PM
Arrow
I dont know exactly but maybe for Cali regulations, and they have AB code injectors and different fuel pump.
A and AA injectors came in the '94-'97 non-california trucks. They are all 90cc injectors and are single shots.
AB injectors came in the '97 cali, and all early '99 trucks. They are split shot injectors meaning they fire a small pilot shot before the main shot. These injectors flow 130-135cc of fuel.
CELAYORK is offline
post #9 of 10 Old 04-30-2013, 05:17 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Thought it was 120cc split shots, some later 96's are Cali models too, and I've still never seen that part on my truck
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 10 Old 04-30-2013, 05:34 PM
c69ss396's Avatar
The accumulator dampens the pulses from the fuel pump to make a smooth constant fuel flow, its needed on the split shot injectors because of surging the pulses would cause under load.
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
