overdrive ? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-28-2013, 09:05 PM Thread Starter
spartan-alteran's Avatar
overdrive ?
hi I got a 1997 f350 im new to theses truck and I wana know watt is the overdrive ?? and wen to uses it ??
spartan-alteran is offline
post #2 of 2 Old 04-28-2013, 09:55 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
It's 4th gear in an auto, and is a ratio less than 1:1 therefore giving you a higher than direct drive ratio, it is 5th gear in the 5 speed and both are used mostly at hwy speeds, 45+ typically
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
