gear swaping question - Ford Powerstroke Diesel Forum
Old 02-19-2008, 09:42 AM
Has anyone here swapped the gears from a 3/4 ton rear to a 1 ton rear? I have a 3:55 geared rearend in a 94 F250 I'm parting out and I would like to swap them into the rear end in my 97 F350 which has 4:10. I have been told by a few people that the gears will work but I would like another opinion before I tear the truck down.
Old 02-19-2008, 09:53 AM
should be the same sterling axle, if so then you should be able to use everything from the donor axle. carrier,gears,shims, and bearings just replace the crush sleeve and retorque the pinion to specs, should be good to go. might wanna check the gear pattern and backlash but it should be close, the housings are machined really close in tolerance
Old 02-19-2008, 09:56 AM
Send a message via AIM to 4everlearning
should be close but you will definatly want to check backlash and runnout.
Old 02-19-2008, 10:19 AM
I was under the impression they are the same axles,the rear at least..
If so....Why not just swap axles?
Old 02-20-2008, 07:26 AM
I had the same situation a few years ago and I just swapped the entire axle. It was a direct bolt up and nothing had to be modified. Lots easier than paying someone to set up the ring and pinion.
Old 02-20-2008, 11:04 AM
My 97 is a dually, and the 94 is a single wheel. The dimension betweent he backing plates is different.
