DE downpipe .... - Ford Powerstroke Diesel Forum
post #1 of 19 Old 04-24-2013, 05:35 PM Thread Starter
ChiefRocka's Avatar
DE downpipe ....
I'm looking to replace my pancake down pipe, so I can finish my exhaust system.
I have alot of FlowMaster 3" pipe with various bends laying around I could build one, but considering my time ... sometimes prefab is the way to go.
Diamond eye has a two piece'r on evil bay...
Thoughts ?
John
2002 F-250, CCSB, 4" Exhaust, Stock otherwise
ChiefRocka is offline
post #2 of 19 Old 04-25-2013, 05:29 AM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
don't get MBRP several people have had fitment issues. i have heard that DE and Tymar are both good. and get a band clamp. it makes it easier if it needs to come apart
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 19 Old 04-25-2013, 05:57 AM
Quoted: 769 Post(s)
X2
And the diamond eye's tailpipe is easier to adjust.
Corey@CNCFAB is offline
post #4 of 19 Old 04-25-2013, 06:31 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I have a diamond eye in my f250 was a huge pain to install, but it was my first time, I just installed an mbrp and went in in an hour, got the mbrp off amazon for $85 shipped, and only thing I did to install was bend the firewall back a bit with my cheater pipe, to remove the downpipe I found it very easy to cut the pipe 3-4 inches away from the turbo, maybe an inch away from the dipstick for the trans, and used my cheater pipe to bend the firewall back around it, get under the truck, unbolt it from the cat, and twist it a little and pull it rite on outta there
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 19 Old 04-25-2013, 07:25 AM Thread Starter
ChiefRocka's Avatar
Cat......what cat ?
Thanks guys....
John
post #6 of 19 Old 04-25-2013, 07:42 AM Thread Starter
ChiefRocka's Avatar
Some even list a 4" downpipe ..... Is that just extremely unnecessary on a otherwise stock truck ?
John
post #7 of 19 Old 04-25-2013, 07:42 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
that's just when removing from a stock system lol
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 19 Old 04-25-2013, 07:42 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
yes extremely unnecessary on a stock truck
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 19 Old 04-25-2013, 08:14 AM
JBRIXEN's Avatar
my MBRP fits like a glove. i didnt even have to bend the pinch weld, before my turbo swap anyway. this has been talked about before. every cab and motor placement is slightly different.
95 F350 CCLB, ZF5, 6637, MBRP dp to 4", GTP38, intercooled, 3" plenums, DIY E-FUEL, TE17*, TS 6 pos, 140v IDM, boost fooler, leveling kit, 315/75/16's, boost, pyro, oil temp
JBRIXEN is offline
post #10 of 19 Old 04-25-2013, 08:23 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
my experience is only to crew cabs, 2 and 4wd tho, and both auto
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
