How to tell gear ratio by counting teeth - Ford Powerstroke Diesel Forum
post #1 of 14 Old 04-24-2013, 03:44 PM Thread Starter
7.3 on 40s's Avatar
Doing some differential work i thought it might be nice to know what gear ratio i have since the sticker with the axle code has peeled and blown away. Searched and found a differential co. online that stated, well in my case if i have a count of 41 on the ring gear and 9 on the pinion that i have 4.56 gears. Does this sound right?
On another note they stated ideal backlash on the ring gear when shimming up the carrier is .010 Is this correct?
97 F350 XLT CC LB 4x4 7.3psd 5spd White/Tan
-Straight Piped
-6637 Intake
-8in. Lift
-Welds w/40in. Rockers
-Warn hubs
-LSD w/4.56 gears
-Leather bucket seats
-Rhino lined
7.3 on 40s is offline
post #2 of 14 Old 04-24-2013, 03:50 PM
boozinag's Avatar
no tag on the diff with the ratio? it'll be 3.55s or 4.10s.
Gerry
'97 CCSB f-250 4x4 auto, 6pos chip w/ canned tunes, AFE intake, 4 in exhaust, 3in dp, 3.55 gears,
Dana 60 rebuilt and waiting to be installed
184k
boozinag is offline
post #3 of 14 Old 04-24-2013, 04:14 PM Thread Starter
7.3 on 40s's Avatar
Ill try and find the site i was on that seemed like it had all the numbers and ways to figure out what gearing you have. 41 ring and 10 pinion are 4.10s and 41-11 are 3.73s. My gears are aftermarket and never asked the PO what ratio. Ill find the site i found this info. on and post back.
-Straight Piped
-6637 Intake
-8in. Lift
-Warn hubs
-LSD w/4.56 gears
-Rhino lined
post #4 of 14 Old 04-24-2013, 04:16 PM Thread Starter
7.3 on 40s's Avatar
drivetrain.com
-Straight Piped
-6637 Intake
-8in. Lift
-Warn hubs
-LSD w/4.56 gears
-Rhino lined
post #5 of 14 Old 04-24-2013, 04:25 PM
boozinag's Avatar
I would be curious to know what gears were installed.
Gerry
184k
boozinag is offline
post #6 of 14 Old 04-24-2013, 04:53 PM
JSchuricht's Avatar
If you still have the gears in the axle, just spin it by hand and count the revolutions between the pinion and ring.
JSchuricht is offline
post #7 of 14 Old 04-24-2013, 05:11 PM
Quoted: 53 Post(s)
Um, just divide the number of ring teeth by the number of pinion teeth....
madpogue is offline
post #8 of 14 Old 04-24-2013, 05:15 PM
boozinag's Avatar
Is it really that simple?!?!?
Gerry
184k
boozinag is offline
post #9 of 14 Old 04-24-2013, 05:16 PM
OL' OutLaw's Avatar
I would be willing to bet you mis-counted the Pinion gear teeth...it's probably got 10 teeth, not nine.....
and yes, it's that simple..... just divide the ring gear tooth count by the pinion gear tooth count....
41 divided by 9 = 4.5555555555
41 divided by 10 = 4.1
etc....
'97 Centurion. F350 4x4 CCLB
Full Force 180cc Stage I's, D66, SRP-1.1, ARP, Banks IC, DIY E-Fuel, EBPV Del & Gut'd Ped., BD Exhaust Brake., SD IDM, HPX, BstFoolr, 4" DP - 4" exh,
6.0 Fan, 180 T-Stat, DIY Don.105006 AF, CCV Mod, BTS, W/ SD Trans Lines, Tru-Cool Max, PML Trans Pan, Bumper Mod, IssPro Gauges, Fluidampr, Mellings LPOP.....
Tuned by "The WildMan".
OL' OutLaw is offline
post #10 of 14 Old 04-24-2013, 05:22 PM Thread Starter
7.3 on 40s's Avatar
Counted again. Marking 1st tooth with paint. 41 and 9. 4.56 it is. sweeeet.
-Straight Piped
-6637 Intake
-8in. Lift
-Warn hubs
-LSD w/4.56 gears
-Rhino lined
