White smoke help. With videos! - Ford Powerstroke Diesel Forum
post #1 of 33 Old 04-23-2013, 07:24 PM Thread Starter
hey guys my dad and I just finished up a frame off resto on a 97 f250. ill make a thread on that some other time but right now im curious why its smoking like this. a little info: only 96,000 on the truck. including the engine. diamond eye 4 inch exhaust no chip. is this amount of whitish smoke normal?? you cant see it in the videos the best but it smokes a little just idling
edit: the motor did sit for around 7 or 8 years without running. my dad did turn it over by hand every once in a while tho
1997 Ford F250 CCSB. Intake. 3in dp 4in straight piped exhaust. Gauges(Pyro,boost,trans temp). Dana 60 swap
power73 is offline
post #2 of 33 Old 04-24-2013, 11:48 AM Thread Starter
anyone
power73 is offline
post #3 of 33 Old 04-24-2013, 12:57 PM
theforeman57's Avatar
Quoted: 4 Post(s)
I know that the worst thing for engines is to sit, even if you turn them over by hand, gaskets can still dry out. Is there any oil if the fuel/ water in the oil/ oil in the water? Injector O rings/ cracked injector cups could be the culprit.Sorry that I could not be of more help.
theforeman57 is offline
post #4 of 33 Old 04-24-2013, 03:25 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Is that on start up or after an hour or so of running?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 33 Old 04-24-2013, 03:30 PM
boozinag's Avatar
also what is the ambient temperature?
Gerry
'97 CCSB f-250 4x4 auto, 6pos chip w/ canned tunes, AFE intake, 4 in exhaust, 3in dp, 3.55 gears,
Dana 60 rebuilt and waiting to be installed
184k
boozinag is offline
post #6 of 33 Old 04-24-2013, 06:17 PM Thread Starter
it was running for around 15 minutes and it was about 45 degrees outside
power73 is offline
post #7 of 33 Old 04-24-2013, 06:22 PM
boozinag's Avatar
15 min seems long enough to be warm. Someone correct me if I am wrong, but white smoke is incomplete combustion of fuel, black smoke is uncombusted fuel, and blue smoke is oil in the fuel/combustion chamber.
For some reason you are getting incomplete combustion. Poor compression? bad rings on the pistons? Does it have any blow by?
Gerry
184k
boozinag is offline
post #8 of 33 Old 04-24-2013, 08:28 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
agreed, check your blowby, can you do a compression test
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 33 Old 04-25-2013, 11:00 AM Thread Starter
how do you check the blowby? and how do you check the compression? remove a injector? sorry guys im still learning
power73 is offline
post #10 of 33 Old 04-25-2013, 11:07 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
gotta make a tool, and pull the glow plugs, pull the oil fill cap while its running and flip the cap on top of the whole upside down, if it blows the cap off your gonna need rings
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
