for guys who installed their pyrometers - Ford Powerstroke Diesel Forum
Old 02-15-2008, 07:01 PM
I had a question I am pretty good at what i do and know i can hoock up all my guages but i had one little question when you drill the hole in the driver side manifold how do you get the burs and metal flakes out would that hurt the turbo.
randy
Old 02-15-2008, 07:11 PM
i took my drill bit an dipped in vaseline before i drilled and had a magnet on the manifold while i was driliing and then stuck a vacum over the hole after i was done. hope this helps.
Old 02-15-2008, 07:12 PM
when i drilled mine i left the engine running and it seemed to blow them all out. i also installed mine in the y pipe. there was a flat area that looked like it was made for it. also, it was easy with the doghouse off on a van.
Old 02-15-2008, 07:13 PM
dip the drill bit in grease, then do the same with the tap. Then use a small magnet in the hole before installing the probe. The exhaust houseing and turbine are pretty stout so no worry's even if ya miss one or two flakes.
KVFD
if you vist diesel manors site it suggests not to do both of those!!!! i just drilled really slow and it worked fine bud so thats my 2 cents!
Old 02-16-2008, 07:21 AM
interesting thanks for the info. I will keep them all in mind as i do them
Old 02-16-2008, 07:24 AM
Rob Rob is offline
you dont have to dip it in vasaline or grease. i would advise against that actually. your better off doing it with the engine off. when you drill you will notice 99% of the shavings fall in your face. then vacuum it real good just to be sure. you will be fine.
Old 02-16-2008, 07:25 AM
just dip it in the greese....and collect as much as you can.....small particles wont hurt the pretty stout exhaust side wheel
Old 02-16-2008, 07:28 AM
Ole White
+1 for the grease and vacuum
Old 02-16-2008, 07:55 AM
Old Head
I'm getting ready to do this myself. The instructions that came with mine say to have the engine running. It seems to me that the sensor goes pretty far into the manifold. Wouldn't this cause some flow restriction? I've been thinking about removing the manifold and drilling it then welding an 1/8" pipe coupler around the hole thus having just the tip of the sensor in the manifold. If done this way what gaskets will I need? Oops! Didn't see this was in the 7.3 forum. I'm runnin' an 05 6.0.
