New MaxTow gauges - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-22-2013, 02:58 PM Thread Starter
Quoted: 4 Post(s)
New MaxTow gauges
I just put a MaxTow tranny temp and a EGR gauges in a pillarpod on my 95 F 350. The tranny I have is an E40D and it's running about 165 to 170 unloaded. EGR is 60 at 2000 RPM. Just wondering if anyone has any numbers on what is a normal temp for the tranny with a 10,000 lb load on it? If not, what is a critical temp for a tranny? Thanks
timlsalem is offline
post #2 of 12 Old 04-22-2013, 03:03 PM
Raul@Stealth Automotive's Avatar
by egr do you mean EGT?
normal temp for your transmission is about 80 degrees above ambient temperature...
Raul@Stealth Automotive is offline
post #3 of 12 Old 04-22-2013, 05:38 PM Thread Starter
Quoted: 4 Post(s)
Yes EGT meant. So it was 90 today in Phoenix and my tranny temp was 170. So this is good?
post #4 of 12 Old 04-22-2013, 10:29 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
That is fine, I end up at about 190-200 pulling grades with about 12k behind me, but mostly flat hwy same weight I run around 180
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 12 Old 04-23-2013, 06:38 AM
yup thats pretty normal... i wouldn't start worrying until you get over 200......
post #6 of 12 Old 04-23-2013, 07:54 AM Thread Starter
Quoted: 4 Post(s)
okay, won't worry about it unless it gets up to 200. Thanks for all the responses.
post #7 of 12 Old 04-23-2013, 08:12 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 45 Post(s)
I installed a 40k tranny cooler in mine recently and went from 175-180* normal driving temp to 125-135* much happier now and though it still gets warm climbing hills with my 12k+ trailer once I'm at the top she cools fast.
600* on the EGT gauge at 2000 RPMs level ground driving is pretty good. Throw on a custom chip and a more efficient compressor wheel and I run down the freeway at 475-530*.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #8 of 12 Old 04-24-2013, 11:27 AM
SoCalPwrStrk's Avatar
My tranny runs about 180 on the flat but throw any hill in there and it will hit 200 easily, just recently i towed my toy box to vegas and hit 220 a few times on my way out there.
"Big Truck" 1997 F-350 CC DRW 4x2 Cali model
Diamond Eye 3" dp to 5" straight pipe, DIY 6637 intake, Pillar gauges, 6.0 trans cooler, Intercooled, TS 6 pos. chip with TW Tunes, 1.0 Housing, Barder Billet Wheel, EBPV Delete
"Baby Truck" 1999 Ranger EC 5 speed 3.slow
Camburg Long Travel, Billit upper arms, Fox dual rate coilovers and double bypass in front, Deaver race pack w/ fox double bypass in rear, fiberglass fenders, 16x8 American Racing Mohave Wheels
SoCalPwrStrk is offline
post #9 of 12 Old 04-24-2013, 04:12 PM
you need a larger trans cooler.....
post #10 of 12 Old 04-25-2013, 07:41 AM
yea, i have the 6.0 cooler but havent had a chance to install it yet. i was hope to get a set of 3/8" super duty cooler lines.
