Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 94-98 7.3L Forums > 94-98 7.3L General Powerstroke Discussion
Old 02-15-2008, 03:56 PM
dirtmod30 dirtmod30 is offline
94 F350 glow plugs
what are you guys using for glow plugs? buy Ford OEM or aftermarket? my truck needs a set, won't start unless I plug it in.... thanks
Old 02-15-2008, 04:05 PM
DonF350 DonF350 is offline
Are you sure you need glowplugs? did you check your relay? I replaced mine with Champs seems to work good but check your relay and your harness with a test light. it might save you a tear down you didnt need
Old 02-15-2008, 05:04 PM
gbear gbear is offline
Powerstroke Techie
Send a message via Yahoo to gbear
I use Motorcraft in My truck. (ZD-11, I think is the part number) but I would check the Glow plug Relay and mke sure it is sending power to the glow plugs.
You might want to read the resistance at the valve cover harness to see which ones are bad and how many. It would also help indicate if the under valve cover harness is giving you problems with bad connections. There is a write up about glow plug system trouble shooting in here some where.
Jim
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
