94-97 Turbo Removal - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-21-2013, 08:05 PM Thread Starter
94-97 Turbo Removal
I am having a bear of a time getting this turbo off.
I have the 4, 10mm out of the pedestal. That sucked.
I am having trouble getting the 2, 15mm nuts off the bottom where the exhaust manifolds connect to the turbo.
I can't seem to get a wrench or socket on either one! left or right.
Irish95 is offline
post #2 of 8 Old 04-21-2013, 11:59 PM
JSchuricht's Avatar
It's a royal pain the first time you do it. For those two lower nuts you need a swivel sockt. A regular socket with a swivel won't work. Remove the EBPV to make the passenger side easier to get to. Also before you put it back together, grind the passenger side flange at a angle right below the hole for that nut your are currently fighting. It will make it much easier to get a socket on the 10mm pedistal bolt during reassembly.
JSchuricht is offline
post #3 of 8 Old 04-22-2013, 10:11 AM
JD3020's Avatar
Get a 15mm wrench, cut the open end off, but leave 2-3" on the box end. The box end will fit, but won't give you much travel. Mark on the wrench where it hits, grind a notch in it, and go to town. We also added notches so a pry bar would fit.
FWIW the passenger side nut froze on my truck, and we ended up pulling the engine to get at it. I had the nut half on, half off, and it was froze solid. Whole stud ended up coming out once i was able to get a longer wrench on it. I've got 3 other collectors here, 2 are missing the same exact stud. But its the same exact threads as the bolts, so i just robbed a bolt and threw in my collector.
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 216k miles: FFD 250/200%'s, stock turbo, built trans, e-fuel, Swamps IDM, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube. Built and tuned by me
97 F-250 ECSB project truck:250/2's, Gen 3, S468, SD axles, studs/springs, ZF-6
JD3020 is offline
post #4 of 8 Old 04-22-2013, 10:18 AM Thread Starter
Do you think I could pull it off with an Extension with wobbler tip?
Thanks for the grinder tip, I noted it on my list of turbo mods.
Thanks for your help!
-Joe
Irish95 is offline
post #5 of 8 Old 04-22-2013, 04:33 PM Thread Starter
Thanks for the help!. I got it off today. I filmed most of the project and went over the tool list. I will post it on Youtube and post a link here for other noobs.
Irish95 is offline
post #6 of 8 Old 04-25-2013, 06:11 PM Thread Starter
I made a Youtube channel and posted some video on the Turbo Removal. Here is the link.
http://youtu.be/aDb78-vYVes
I also made a video for the EBV Delete.
'94 - '03 Pwerstroke EBV Delete - YouTube
Maybe this will help anther DIY'er.
I am working on a rebuild video now.
Irish95 is offline
post #7 of 8 Old 04-26-2013, 07:35 AM
Thanks for the videos. It will most certainly help me.
ToddM715 is offline
post #8 of 8 Old 04-26-2013, 11:16 AM Thread Starter
Thumbs up
If the video helps. Please, Like and Subscribe, also, if you call Pure Trubo in Oceanside, CA. & Mention the Youtube channel you get %10 off any order!
Irish95 is offline
