ReAr shackle flip where to put exhaust? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-20-2013, 07:00 PM Thread Starter
I flipped shackles on the rear springs to get some lift without blocks. Now my springs are to low to mount my 5" tailpipe. I'm not a real fan of stacks. Curious on anyone's thoughts if I run the exhaust to the outside of the frame rail up and over front spring mount right alongside frame then go down behind rear helper spring mount to stock location. Probly hard to picture, but picture the back of rear spring 8" lower and both helper spring mounts are about flush to bottom of frame. I can probly make it work. The pipe would end up being about 6 to 8 inches Away from inside of tire. Anybody think that will cause issues?
97 ccsb, superduty 3:73 axles, superduty springs, 35's, cold air, ebpv delete, 3" down pipe, 5" exhaust
Patlschr is offline
post #2 of 3 Old 04-21-2013, 05:04 AM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 4 Post(s)
Feedback Score: 3 reviews
I have the SKY rear shackle flip on mine, here is how i routed my exhaust, custom cut & fit and welding required though.
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #3 of 3 Old 04-21-2013, 10:10 AM Thread Starter
I really want to get it up tight to the bottom of box. I will be plowing with the truck, and after 12 hours of living in the truck going back and forth you start to get really bored. Then fight that with seeing how fast you can go, and before you know it your backed into to a snow bank with a broken tailpipe. I'm probly just going to end up making it exit in front of tire.
Patlschr is offline
