Did I just fry my PCM? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-20-2013, 11:29 AM Thread Starter
bignate's Avatar
Did I just fry my PCM? RESOLVED
So I was installing my new chip today and all was going good. First startup went great then this...
Key in ignition and turned to the run position.
http://i53.photobucket.com/albums/g5...ps798f0efa.mp4
So I'm ordering a new one today... This sucks.
But on a brighter note I got my new front speakers in!
Nate
1996 F250 4x4 7.3 5 Speed Ex Cab Short Box. Mods: 6637, 3"DP, 4" Exhaust, Beans 6pos Chip, Isspro 2 Pyro-Fuel-Boost, 255/85R16, 216,000 miles
Boost Fooler, 203deg Thermostat and Custom 12" sub center console on the way...
Wishing I was Fishing...
bignate is offline
post #2 of 10 Old 04-20-2013, 11:48 AM Thread Starter
bignate's Avatar
I'm going to wait until Monday and call the shop that I ordered the chip from. Any ideas of what else to check/do before then?
So I'm now looking for a PCM coded ALF6. If you've got one on the shelf, I've got cash...
Nate
bignate is offline
post #3 of 10 Old 04-20-2013, 11:49 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Check all fuses under hood and in dash?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 10 Old 04-20-2013, 11:56 AM
c69ss396's Avatar
remove the chip and see what happens....
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #5 of 10 Old 04-20-2013, 01:49 PM Thread Starter
bignate's Avatar
Pulled the chip. Then I made the video. Checked all fuses... All look good, I will double check when I head back out to the shop.
Thanks for the ideas, keep them coming!
Nate
bignate is offline
post #6 of 10 Old 04-20-2013, 02:40 PM
c69ss396's Avatar
check for a bad ground, also check and make sure you didn't bend a pin on the pcm and check the connector and make sure you didn't push in a pin.
c69ss396 is offline
post #7 of 10 Old 04-21-2013, 02:19 PM
mkeith54's Avatar
Did you have the key in the ignition when you installed the chip or removed it? If so I'd bet you killed the PCM.
Mike Keith
New Florence Mo
1996 F-250 ECSB, 6-pos/ts chip/ Tymar intake
Pyro, boost, and tranny gauges
mkeith54 is offline
post #8 of 10 Old 04-21-2013, 04:05 PM Thread Starter
bignate's Avatar
No key in the ignition. I followed the directions exactly...
Nate
bignate is offline
post #9 of 10 Old 04-22-2013, 04:55 PM Thread Starter
bignate's Avatar
So after reading alot more today, I had my list of things to double check.
#1 was relay that was clicking rapidly. Swapping made no difference.
#2 was double check the charge on the batteries. All good. "Hey that positive terminal doesn't look seated." Re-ajust and try it... Woo Hoo!!!
Now I get to hang my head in shame as I didn't connect the battery well enough
Thanks for the help guys.
I swear God has a since of humor when teaching patience and perseverance...
Nate
bignate is offline
post #10 of 10 Old 04-22-2013, 09:55 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Glad you got it all figured out then bro, hell of a lot cheaper than replacing a PCM lol
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
