oil pressure - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-20-2013, 11:26 AM Thread Starter
PowerstrokinIt F250's Avatar
oil pressure
just bought a 95 f350 today and love it, but when i got it home, the oil pressue guage quit working. it reads high when im driving and when i shut the truck off it stays high, but when i cycle the key it goes down to nothing, then back up to high. oil level is good, did notice an abnormally small oil filter on it, but im guessing its the guage since it doesnt make sense for there to be oil pressure with the engine off. any ideas??
[IMG]http://i59.tinypic.com/33l06ll.jpg
1995 f350 7.3 4x4 auto 4door long bed 160,000 miles BONE STOCK for now. Cleanest truck in PA
1998 Mitsubishi Eclipse GSX 9.9@ 152mph
2003 Honda Civic daily driver
PowerstrokinIt F250 is offline
post #2 of 8 Old 04-20-2013, 08:13 PM
boozinag's Avatar
The filter should be pretty darn big. A small filter does not sound right...
Gerry
'97 CCSB f-250 4x4 auto, 6pos chip w/ canned tunes, AFE intake, 4 in exhaust, 3in dp, 3.55 gears,
Dana 60 rebuilt and waiting to be installed
184k
boozinag is offline
post #3 of 8 Old 04-20-2013, 08:14 PM
boozinag's Avatar
Change the oil as replace with the correct size filter is where I would start.
Gerry
184k
boozinag is offline
post #4 of 8 Old 04-20-2013, 10:42 PM Thread Starter
yeah i always had big filters for my other ones, but this is the right size and everything just not as long as the other ones. it has a new oil change i think im just gonna put the right filter on it and start from there but im pretty sure the guage just isnt working right
post #5 of 8 Old 04-21-2013, 03:55 PM
mkeith54's Avatar
The Oil sending units on these trucks are not analog, they are simple switches that make at a set pressure. The gauge typically reads around middle high.
Mike Keith
New Florence Mo
1996 F-250 ECSB, 6-pos/ts chip/ Tymar intake
Pyro, boost, and tranny gauges
mkeith54 is offline
post #6 of 8 Old 04-24-2013, 06:11 PM Thread Starter
know thats where my other truck usually reads, but this one is completely maxxed out sometimes, i cant figure it out unless its just the guage
post #7 of 8 Old 04-24-2013, 06:14 PM
OL' OutLaw's Avatar
change the sensor, you can try one off your other truck....
if it reads right, well.................
'97 Centurion. F350 4x4 CCLB
Full Force 180cc Stage I's, D66, SRP-1.1, ARP, Banks IC, DIY E-Fuel, EBPV Del & Gut'd Ped., BD Exhaust Brake., SD IDM, HPX, BstFoolr, 4" DP - 4" exh,
6.0 Fan, 180 T-Stat, DIY Don.105006 AF, CCV Mod, BTS, W/ SD Trans Lines, Tru-Cool Max, PML Trans Pan, Bumper Mod, IssPro Gauges, Fluidampr, Mellings LPOP.....
Tuned by "The WildMan".
OL' OutLaw is offline
post #8 of 8 Old 04-24-2013, 06:30 PM
JD3020's Avatar
I'd ignore it completely. Only thing that gauge shows is if the engine has pressure. Which you can tell if it has pressure, by if the engine is running. A HEUI needs oil pressure to run. If you want to test pressure get an actual gauge for it, and either put it in place of the stock sensor, or on the oil cooler.
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 216k miles: FFD 250/200%'s, stock turbo, built trans, e-fuel, Swamps IDM, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube. Built and tuned by me
97 F-250 ECSB project truck:250/2's, Gen 3, S468, SD axles, studs/springs, ZF-6
JD3020 is offline
