95 f250 ext-cab 7.3 will it do the job? (Towing) - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-20-2013, 03:56 AM Thread Starter
New to the form and PSD's
I'm going to look at this truck, 1995 Ford F250 Extended Cab - 7.3 Turbo Diesel
It will be used to pull a 9k lb 5th wheel, will it do it?
I want to be able to pull at 70mph on the interstate. I plan on upgrading the intake and the DP
I say 70mph because I do not want to get ran over or cause a wreck, I have seen to many close calls with ppl pulling at 60mph on the interstate.
I owned a 93 7.3 idi non turbo and it would not pull the 5th wheel up any grade without dropping to 50mph
Thanks
Bryanj58 is offline
post #2 of 6 Old 04-20-2013, 05:01 AM
7.3 on 40s's Avatar
I just pulled 7500 lbs. off my hitch 750 miles on the interstate going 65-70mph. As long as the truck is mechanically sound you should not have an issue. I only have intake and exhaust. But i also have 40 inch tires which doesnt help to tow with. I would also rec. a good chip. Starting to think i need a chip myself.
97 F350 XLT CC LB 4x4 7.3psd 5spd White/Tan
-Straight Piped
-6637 Intake
-8in. Lift
-Welds w/40in. Rockers
-Warn hubs
-LSD w/4.56 gears
-Leather bucket seats
-Rhino lined
7.3 on 40s is offline
post #3 of 6 Old 04-20-2013, 06:40 AM
dr.deere's Avatar
Quoted: 19 Post(s)
You shouldn't have any issue I've pulled 16k on the deck of my 8k flatbed at 70 on the interstate all stock motor with 277k miles on it
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #4 of 6 Old 04-20-2013, 09:20 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Should do it fine, but pulling a grade and maintaining speed while hauling usually don't go hand and hand
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 6 Old 04-20-2013, 05:49 PM Thread Starter
Thanks for the info, I ended up passing on the truck. Had to many problems they were fixable but more time and money so ill keep looking
Thanks again
Bryanj58 is offline
post #6 of 6 Old 04-20-2013, 06:01 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Well good luck, sometimes the best deals need a little work, my 300k mile stock dually leaked oil shut down when cold, and needed love, now $50 later, air filter, fuel filter, permatex and a CPs later it's a reliable daily driver
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
