Am I expecting too much from my 96? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 04-19-2013, 01:41 PM Thread Starter
96 F350 quad-cab dually. Stock except for a US gear 2 speed aux trans and maybe a US gear chip? Just got back from a 1000 mi round trip to NC towing my Land Rover on a 2 axle trailer (~8000 lbs gross). Got around 12 mpg @ 60mph. Mileage doesn't bother me as much as a seemingly lack of power. On 80 percent of normal highway driving, dropping it out of OD would get me up the hills at speed. Anything more, especially a few steeper grade hills would cause it to bog down horribly. Normal? I have a DP to install and am going to do the air filter mod this summer. Without modding the exhaust more than the DP, would a custom tunes chip by itself get me up the steeper hills any faster?
Thanks - Bill
helievacpilot is offline
post #2 of 13 Old 04-19-2013, 01:45 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Yes it would, but I would recommend an intercooler as well to keep the egt's down, and gauges to monitor it all
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 13 Old 04-19-2013, 06:14 PM Thread Starter
Just finished a 6.0 trans cooler install. Intercooler was lower on the list. With guages to monitor things, was hoping to get away with a custom tunes chip to give it a little extra oomph.
- Bill
post #4 of 13 Old 04-19-2013, 07:47 PM
boozinag's Avatar
Are you an army 67J?
Gerry
'97 CCSB f-250 4x4 auto, 6pos chip w/ canned tunes, AFE intake, 4 in exhaust, 3in dp, 3.55 gears,
Dana 60 rebuilt and waiting to be installed
184k
boozinag is offline
post #5 of 13 Old 04-19-2013, 08:45 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
That question makes no sence, I cannot in good faith say get custom tunes before gauges, I've had mine up to 1400+ with an ic and custom tunes, I do tow in extreme, but I WATCH my gauges
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 13 Old 04-20-2013, 05:28 AM Thread Starter
What question are you referring to? I stated that I would get the gauges and the chip at the same time.
post #7 of 13 Old 04-20-2013, 05:29 AM Thread Starter
Civilian EMS pilot.
post #8 of 13 Old 04-20-2013, 10:02 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
The question he asked and is what you last quoted
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 13 Old 04-20-2013, 02:56 PM Thread Starter
Ah. Also, hadn't thought of it before, but when the downpipe goes in, I'm going to gut the cat.
post #10 of 13 Old 04-20-2013, 02:59 PM
jesilvas's Avatar
Quoted: 2 Post(s)
You might have boost leaks, exhaust leaks pre turbo, low fuel pressure, worn injectors, low injector control pressure, and a number of things.
4R100, 2wd
330,000 + miles
jesilvas is offline
