Differential help needed after long tow - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-19-2013, 09:18 AM Thread Starter
7.3 on 40s's Avatar
In the process of moving down south and just the other day took first trailer load down. 750 miles round trip. Truck did pretty well pulling 7k lbs. Trailer had a tire blowout which sucked but that's besides the point. Anyways pulled rear diff cover off this morning because cover had a leak and i have never taken a look in there since i bought the truck. I have attached some pics for you to check out. First thing is im 99% i have LSD because the clutch packs on each side of the spider gears. Correct me if im wrong. But the major thing i noticed was thin looking shim things popping out of each side on the outer side of the carrier bearing caps. Very easy to see in the pics. Can someone please give me advice on as to what these things are and also what i need to plan on doing to fix it. Have another 7k lbs. to tow down in 2 weeks. Should be plenty of time to tackle whatever job needs to be done. Went ahead so far and purchased 4 quarts of motorcraft 75-140 synthetic gear lube, 8 oz. of motorcraft friction modifier, and felpro cover gasket. Any help is much appreciated.
ID:	99194   Click image for larger version
ID:	99202   Click image for larger version
ID:	99210   Click image for larger version
97 F350 XLT CC LB 4x4 7.3psd 5spd White/Tan
-Straight Piped
-6637 Intake
-8in. Lift
-Welds w/40in. Rockers
-Warn hubs
-LSD w/4.56 gears
-Leather bucket seats
-Rhino lined
7.3 on 40s is offline
post #2 of 6 Old 04-19-2013, 11:51 AM Thread Starter
7.3 on 40s's Avatar
Sorry for the double post but i have been researching all day and found a little info. If you look at my bearing caps. You see the arrows pointing inward. Service info says the arrows must point outward. Also it seems as if the thin circles of metal sticking out of the shim locations are actual shims. How they slid out im not sure but maybe it has to do with the caps being on backwards.
-Straight Piped
-6637 Intake
-8in. Lift
-Warn hubs
-LSD w/4.56 gears
-Rhino lined
post #3 of 6 Old 04-19-2013, 05:11 PM
m j
someone used a cheapo install kit to work on that dif. and raped the shims trying to get carrier preload.
yukon master install kit uses a captured style shim that woud have prevented that ugliness.
1997 F250 rclb 4x4, Comp910s, SRP1.1, Irate T4 s468,FullForce 350/200, homebrew efuel with i̶n̶ ̶t̶a̶n̶k̶ ̶a̶e̶r̶o̶m̶o̶t̶i̶v̶e̶ ̶1̶1̶1̶4̶2̶ A1000 5/8" drawstraw, Diesel Innovations fuel rail feed fittings, balljoint D60f Detroit Locker, zf5 sachs K70263-01CB ceramic clutch , Grizzly locker 10.25, 315/75/16 Wrangler MT/Windowed 7.3 Oct 9/14
m j is offline
post #4 of 6 Old 04-20-2013, 03:54 AM Thread Starter
7.3 on 40s's Avatar
I have been researching carrier preload. How is the carrier preload set? I do understand it seems as if someone when the cheap route when installing a gear set. I have not removed the caps yet but i can actually move the shims back and forth with my fingers. Im sure that should not be the case.
When you say captured style shim, is that a design that does not let them pop out?
I think i have an idea on how to repair this. Axles come out then remove caps and take out carrier then reinstall with new shims and get the carrier preload right then set the backlash to around .010 Please correct me if this sounds wrong.
-Straight Piped
-6637 Intake
-8in. Lift
-Warn hubs
-LSD w/4.56 gears
-Rhino lined
post #5 of 6 Old 04-20-2013, 07:27 PM
m j
this is a 'before' pic of mine when I installed the Grizzly locker.
looks like the arrows do point out.
the 'shims' from the factory are one piece. I guess they have an assortment and the assembler pics the correct ones to install.
the rest of us have to make a stack of shims.
this link should show a small pic of the Yukon shims and fancy holder for them. it sandwiches the thin ones between machined interlocking pieces
carrier preload is set by getting your backlash to spec, then adding equal shims on either side for final assembly. there is a spec on how much to add (Differentials book on page 259 states 12 thou for the fords as typical) http://www.amazon.com/Differentials-Identification-Restoration-Jim-Allen/dp/1424326613/ref=sr_1_1?ie=UTF8&qid=1366514811&sr=8-1&keywords=differentials+identification+%26+repair
m j is offline
post #6 of 6 Old 04-20-2013, 11:27 PM Thread Starter
7.3 on 40s's Avatar
Thanks for the pic. Yest. I removed the axles then removed caps and pulled carrier out. The shims that were sticking out were mangled and bent up. They did not even look like they were the right size to begin with. Tom. I need to order a shim kit. I was looking at the yukon and dts websites at super shims. On the left side of my carrier i had 5 shims. 2 medium and 3 very thin. On the right side i had 1 large shim and 1 thin. Hopefully i can minimize the amount of shims with a kit. Im sure the less number of shims the better. Still wondering how these new shims are designed to keep from backing out.
-Straight Piped
-6637 Intake
-8in. Lift
-Warn hubs
-LSD w/4.56 gears
-Rhino lined
