Fuel return question - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-18-2013, 01:43 PM Thread Starter
I have a 1996 F350 dually with the powerstroke engine and has the factory dual fuel tanks. Does the fuel return divert the unused fuel back into the selected tank or does it split it back into both tanks? I cannot use the front tank because it wont fill up and I haven't done a vent mod yet. The front tank was next to empty so I have been using the rear tank only. After putting about 7 tanks of diesel through the rear tank, I was curious to how much I had in the front tank and switched over while driving. I now have a little more than a quarter tank in the front. I have not added any diesel to the front, only the rear, yet I have mysteriously added fuel to the front. That made me suspect the fuel return divided the excess fuel into both tanks. Can anyone confirm this? Thanks!
j.pearson is offline
post #2 of 5 Old 04-18-2013, 01:52 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Usually it diverts to both, rite back to the selector valve, but that makes me wonder since I primarily only use my front to keep my wallet happy at the pumps lol, but gotta love a regulated return
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 5 Old 04-18-2013, 02:02 PM
It "should" return to the tank that it is pulling from...but I could see the possibility of an internal leak In the selector valve that could let some find its way back into the other tank. Weirder stuff happens on a regular basis!
Reed
1997 CCLB 4x4 ZF, 295-75-16 BFG A/T's, 16x8 ARE Outlaw II's, DP & 4" exhaust, 4" Skyjacker Suspension kit, FPR shim, DIY intake, Autometer boost and pyro, PHP Hydra Chip, DIY 140V IDM and E-Fuel are next!
Reed P is offline
post #4 of 5 Old 04-18-2013, 03:35 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
^x2
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #5 of 5 Old 04-19-2013, 06:26 AM
OL' OutLaw's Avatar
yep, it does switch both feed and return.....like he said above tho, if the Walf is leaking inside, (read dirty messed up Walf), then you could get some fuel back into the un-selected tank
Oh, and that's my Swedish impression for the day....
'97 Centurion. F350 4x4 CCLB
Full Force 180cc Stage I's, D66, SRP-1.1, ARP, Banks IC, DIY E-Fuel, EBPV Del & Gut'd Ped., BD Exhaust Brake., SD IDM, HPX, BstFoolr, 4" DP - 4" exh,
6.0 Fan, 180 T-Stat, DIY Don.105006 AF, CCV Mod, BTS, W/ SD Trans Lines, Tru-Cool Max, PML Trans Pan, Bumper Mod, IssPro Gauges, Fluidampr, Mellings LPOP.....
Tuned by "The WildMan".
OL' OutLaw is offline
