EBPV Delete - Ford Powerstroke Diesel Forum
Old 02-12-2008, 04:01 PM
EBPV Delete
what is the easiest way to turn off the EBPV on a stock 96er??
Old 02-12-2008, 04:02 PM
easiest way is just to unplug it......it will throw a code but the code wont turn the CEL on...
Old 02-12-2008, 04:04 PM
cel?? you mean the light on the dash???
unplug the soleniod i presume??
yes sir....and yes sir.....
Old 02-12-2008, 04:08 PM
what is a EBPV?
Old 02-12-2008, 04:10 PM
BIG TRUCK, SMALL DRIVER
Exhaust Back Pressure Valve. It's on the outlet of the turbine and closes to warm the engine in cold weather.
Old 02-12-2008, 04:12 PM
thanks, i have the complete tech manual on my truck that i got from my local Ford dealer. i think i found the solenoid.
what differences should i expect to see??
Old 02-12-2008, 04:13 PM
no performance difference except when the motor is cold....then the valve wont close robbing you of performance...
Old 02-12-2008, 04:15 PM
You may have to remove the intake tube that goes from the air filter to the turbo. The plug is bolted to the inlet of the compressor housing. It is a two wire plug.
Old 02-12-2008, 04:18 PM
What is that? I dont have one of those
