How much weight - Ford Powerstroke Diesel Forum
post #1 of 21 Old 04-18-2013, 06:45 AM Thread Starter
vandy's Avatar
How much weight
Would u load in the bed of an f350 longbed? I might have to make a haul that could be as heavy as 2k lbs. Seems like quite a bit to me
vandy is offline
post #2 of 21 Old 04-18-2013, 06:48 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 1034 Post(s)
Feedback Score: 6 reviews
2k lbs = 1 ton and an F-350 = a 1 ton
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #3 of 21 Old 04-18-2013, 06:59 AM
Blue Goose's Avatar
IMO, you are good as far as weight goes, just get it as far forward as possible to get some of the weight on top of and in front of the rear axle. Should handle just fine.
06 KR 250
Blue Goose is offline
post #4 of 21 Old 04-18-2013, 07:09 AM
sprksonu's Avatar
i have had 3.250lbs in the back of my lifted 250 just take it easy and plan ahead lol
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #5 of 21 Old 04-18-2013, 07:12 AM Thread Starter
vandy's Avatar
It is in a 275gal tote so i can put it where need then fill. Its about a 30ish mile drive then down loaded
vandy is offline
post #6 of 21 Old 04-18-2013, 07:22 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Seems easy enough, but what's a 275gal tote? Put it up against the front of the bed for more stability and not such a nose high feeling
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 21 Old 04-18-2013, 07:30 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
I had 4k of stone in the bed of my 95 with no issues.
dhanna6powerstroke is offline
post #8 of 21 Old 04-18-2013, 07:32 AM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
Haha! Sorry but this is funny, just last weekend I had 4+ tons in my truck (dually but still) so 8000+ lbs of dirt. So yea you'll be fine.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #9 of 21 Old 04-18-2013, 07:33 AM Thread Starter
vandy's Avatar
vandy is offline
post #10 of 21 Old 04-18-2013, 07:34 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
I'm with these guys. I've have 5000 in the back of my F250. 1 ton of material settles my suspension 1".
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
Tags
derailed already
