Need Parts Help - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-16-2013, 07:13 PM Thread Starter
Quoted: 9 Post(s)
Need Parts Help
Does anyone have a used fuel tank selector valve they would be willing to sell. Mine is leaking all over the place. There are only OBS gas trucks in my local junk yards and I can not afford $200 - $300 for a new one. Is there any mod out there that will let me use a cheaper valve and still have the gauges read and the tanks flip correctly? In my opinion these trucks do not have enough fuel on board as is I do not want to lose one of the tanks by plumbing it straight.
1997 Crew Cab Long Bed 4X4 (DRW Conversion) Auto. 280K miles
Stainless Irate Bellowed Up Pipes
Fresh Turbo with 1.0 Housing & Wicked Wheel II, 3" downpipe with 4" exhaust, Intercooled, 6.0 Fan, 39 gal rear fuel tank + 70 gal Transfer Flow in the bed, Hydroboost, Completely New Suspension (Springs, Shocks, Bushings),08 Rear Diff Cover, Baby Swamps, Hydra Chip with Swamps Tunes, and Swamps IDM, Dually Swap, Tru-Trac locker in the rear, Red Head Steering Box and Borgeson Steering Shaft
ChallengerRV is offline
post #2 of 6 Old 04-17-2013, 12:58 AM
birdco85's Avatar
I have the gasser one on mine, works fine, no leaks. Just get the harness with it cuz its a tad smaller. Got mine for $15
1995
F350 PSD, 4x4, CCLB, Auto, 236,xxx, Tymar, 4" Diamond Eye, PHP FU2 chip, T-500, Rosewood Stage 2.5's, DIY E-fuel, Intercooler, Gauge's (Pyro, Boost, Trans), CCV Mod, Explorer OHC....way more to come.
birdco85 is offline
post #3 of 6 Old 04-17-2013, 09:06 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 57 Post(s)
The Ford part number for the selector valve has been updated and finalized as a 6C3Z9189A. Runs gas or diesel back to '85.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #4 of 6 Old 04-17-2013, 09:12 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
2000-7.3L is offline
post #5 of 6 Old 04-17-2013, 11:15 AM
JBRIXEN's Avatar
if you need more fuel capacity..... this will give you almost 60 gallons of fuel.It's done......38 gal rear fuel tank - PowerStrokeNation : Ford Powerstroke Diesel Forum
95 F350 CCLB, ZF5, 6637, MBRP dp to 4", GTP38, intercooled, 3" plenums, DIY E-FUEL, TE17*, TS 6 pos, 140v IDM, boost fooler, leveling kit, 315/75/16's, boost, pyro, oil temp
JBRIXEN is offline
post #6 of 6 Old 04-17-2013, 06:22 PM Thread Starter
Quoted: 9 Post(s)
Thanks guys. There are several gasser OBS F150's and 250's in my local U pull and pay. That will save me a boat load of $$. Maybe even enough to put in a shiny new 38 gal tank.
