PCM and hpop questions? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-16-2013, 03:25 PM Thread Starter
Rfort95's Avatar
Anybody know where I can but a pcm at either new or used..... I looked on eBay and didn't see anything... Can I put a superduty hpop in my OBS 95 f350... I've saw guys talking about the different degrees of them but I'm not really sure.
Rfort95 is offline
post #2 of 6 Old 04-16-2013, 07:53 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
Check out RockAuto.com for a PCM (I got one for my 94 through them for $115 plus refundable core). A SD 17* pump will not work directly on your 95 due to bleed-down issues. You would need to have a vendor like Terminator put the SD parts in the earlier body (or something like that). Cheers!
Patrick Feeley is offline
post #3 of 6 Old 04-17-2013, 11:56 AM Thread Starter
Rfort95's Avatar
Thanks a lot although I'm having trouble finding the pcm on the page is there something else I should type in
Rfort95 is offline
post #4 of 6 Old 04-17-2013, 01:18 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 51 Post(s)
they call it an ECM. Go Ford->1995->F350->7.3Diesel->Electrical->ECM
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #5 of 6 Old 04-17-2013, 01:45 PM Thread Starter
Rfort95's Avatar
Ahh thanks thanks a lot!
Rfort95 is offline
post #6 of 6 Old 04-17-2013, 04:48 PM
Quoted: 15 Post(s)
And the picture they usually show is wrong (but don't worry about it). Cheers!
