Gauge decision - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-16-2013, 10:55 AM Thread Starter
Gauge decision
I am looking at getting gauges for my 97 cclb auto trans and I am having a hard time deciding what gauges to get. I only want a triple pod and I know I want to use an aeroforce interceptor. With this gauge and all that it can do what other gauges do I need (pyro, trans, boost). In other words what gauge of those three can i get rid of and still have the most accurate readings.Future mods 3dp 4" straight, d66, t500 and in the long haul stag 2.
I am planning on doing the e fuel upgrade so I would like to add fuel pressure to the aeroforce do I need to something else with this gauge to read this.
fowllivin is offline
post #2 of 9 Old 04-16-2013, 11:14 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 43 Post(s)
Since the interceptor gauge only sees what the PCM sees then of the standard three gauges I would vote to not buy the Boost gauge (MAP sensor sends that signal to the PCM for which the Interceptor would see it also). The trans temp sending unit is slow and can be way off. In general the PCM only needs it to report if the tranny gets to 280*. The EGT gauge and Tranny temp gauge should come with there own sending units designed to work with that gauge.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 9 Old 04-16-2013, 12:39 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I have an aero force, I would suggest boost and pyro with it, the PCM does read boost but your future plans are going to have your over boosting and the scan gauge will no longer read it correctly, and you should easily hit high psi numbers so I suggest either 0-60 or 0-100 psi boost gauge
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 9 Old 04-16-2013, 01:38 PM
BR'sCrewCab's Avatar
I agree, I have an aero force and purchased the additional sensors for boost and pyro and have been very happy with it. I don't run any other gauges. When I tow, I have mine set up to alert me with the red lights if my trans temp gets too hot. Otherwise, I just watch my egt and boost. Also helps on warm up in the winter as I can monitor the oil temperature to make sure she's ready for driving.
96 F250 Crew Cab XLT
125,000 miles, Full Force Stage 1 Injectors, 4:10 rear, Dana 60 Swap, F350 Rear Lift Blocks, 325/60R18, 3" Down Pipe, 4" Exhaust, Tymar Intake, Aeoroforce Interceptor, DP Tuner (no start, stock, high idle, drive thru, 80 Eco, 60 Eco, 60 tow, 120 hp Race Tune), 7.3 Intercooler, 2.25 PMF RSK, V-Code Front Springs, B Code Rear Springs, Complete Alpine Audio System Upgrade, Tru-Cool Trans Cooler, Pro Comp 1069 18x9 Rims, John Woods Tow Master Transmission, Air Lift Air Bags
BR'sCrewCab is offline
post #5 of 9 Old 04-16-2013, 03:28 PM Thread Starter
I am a little confused. Are you guys saying just buy the aeroforce interceptor and then buy the aeroforce egt probe and pyro kit or buy the aeroforce and then buy issopro ev2 boost and trans gauge?
I just want to buy once and try to keep the costs as low as I can but still have 3 gauges that will run everything I need now and for future mods. Thanks for input.
post #6 of 9 Old 04-16-2013, 03:37 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
buy the aero force, and get your choice of boost and pyro other than the add on connectors for the aero force, my 97 has all regular gauges, and no aero force, my 95 has the aero force, and its neat and all but I like the 4 gsauges on my pillar
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 9 Old 04-16-2013, 04:00 PM
I only have the aeroforce interceptor and no other gauges. If you want to go this route, you will need to buy the egt probe and boost kit from aeroforce as well. This will allow you to see both inputs on the gauge at the same time. Then, I have the gauge set up to alert me if my trans temp gets too hot. That happens with the red led lights on the gauge.
post #8 of 9 Old 04-16-2013, 06:16 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 43 Post(s)
Sorry fowllivin, I figured the aeroforce displayed boost like the edge does. Off the MAP sensor.
Matt
'97
-Stage II trans.
BigFuel is offline
post #9 of 9 Old 04-16-2013, 08:06 PM Thread Starter
It's fine, I have no idea either new to the diesel world
