Cleaning the Fuel Pressure Regulator - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-11-2008, 08:43 AM Thread Starter
Frank 93L's Avatar
Send a message via Yahoo to Frank 93L
I'm attempting to clean my fuel pressure regulator (Not the IPR). I have the procedure on Alldata, but I'm slightly confused and was hoping someone here could explain it a little better. Alldata says:
1. Remove the air cleaner assembly and the air inlet tube.
2. Remove the fuel pressure regulator cap, spring, and spool valve from the fuel control valve.
3. Thoroughly clean the fuel pressure regulator bore in the fuel control manifold.
Now what I don't understand is:
1. What is a spool valve? I removed the cap and spring, but no spool valve. I'm assuming it's in the same place as the cap and spring?
2. The picture that Alldata supplies just shows an arrow pointing vaguely at this whole assembly, and it's labeled "fuel control manifold."
So which part is the manifold, where is the bore and spool valve, and what's the significance of removing the cap spring and spool valve unless that's the "bore" I'm supposed to thoroughly clean (which I don't think it is because it says the cap is to be removed from the fuel control valve, not the control manifold.)?!
Anybody ever done this?
1996 PSD. 217,XXX miles. 5 speed.
I'm doing this in an attempt to cure a loping idle.
Frank 93L is offline
post #2 of 10 Old 02-11-2008, 09:45 AM
SMKSTAX's Avatar
Are those directions for an OBS truck?? I'm confused.
RICK
97 F350 CREW CAB 4x4, 7.3 TURBO DIESEL, DIY INTAKE , TW TUNES
GRAND ROCK POWERFLOW STACK KIT W/5" MITRES
3.55 REARS, 3" DOWNPIPE, FPR SHIMMED WITH GAUGE
SMKSTAX is offline
post #3 of 10 Old 02-11-2008, 09:50 AM Thread Starter
Frank 93L's Avatar
Yes they are for an obs truck. They're actually the directions for a 97 because Alldata apparently has a glitch. If you look up this procedure for a 96 it has you trying to clean the IPR, not the FPR. Maybe these instructions aren't correct either.
post #4 of 10 Old 02-11-2008, 10:01 AM
SMKSTAX's Avatar
Well the FPR or fuel header is on the drivers side of the fuel filter housing no where near your air cleaner assembly. So these directions make no sense to me.
RICK
SMKSTAX is offline
post #5 of 10 Old 02-11-2008, 10:14 AM Thread Starter
Frank 93L's Avatar
Yes we're talking about the same thing. I don't know why it says to remove the air cleaner assembly. I didn't remove it. But we're talking about the FPR, right next to the fuel filter. When it says "Remove the fuel pressure regulator cap, spring, and spool valve from the fuel control valve" they're talking about the same cap and spring you remove to do the FPR shim with the BB.
post #6 of 10 Old 02-11-2008, 10:21 AM
SMKSTAX's Avatar
Well you can clean that out but i would also remove the FPR from the housing and clean the screen also.
RICK
SMKSTAX is offline
post #7 of 10 Old 02-11-2008, 11:54 AM Thread Starter
Frank 93L's Avatar
Well I just cleaned the screen. What a PITA. FYI, always lay paper towels under the FPR, and don't drop the screen. No noticable difference in idling though. It's still loping at idle after warmup.
post #8 of 10 Old 02-11-2008, 05:25 PM
Be sure you didn`t drop the o-ring that goes over the screen. Thats what I did.
97 F-350, 7.3 psd, xlt, limited edition, obs, dually, E40d at, 410 r axle, reg. cab, 8ft bed, 145000 miles, DIY Tymar intake (napa filter) CCV mod. fpr bb mod, HPX crossover pipe, SS Bully steps, Reese Fifth wheel hitch, CB Radio, 3" DP /4" back w/cat delete and 4" flow-thru muffler w/5" tip.
Triflex is offline
post #9 of 10 Old 02-11-2008, 06:07 PM Thread Starter
Frank 93L's Avatar
If you're talking about the one that is on the regulator and butts up to where the screen is, yes I did drop it. Luckily I have alot laying around and just replaced it.
post #10 of 10 Old 02-11-2008, 06:13 PM
Thats the one and I didn`t have any so here I am getting a friend to drive me 24 mi. to get the little Bas%$#*. Ha.
Triflex is offline
