Going away for the summer - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-16-2013, 08:29 AM Thread Starter
June 11th I am leaving for basic training and i will be gone for 19 weeks. I have 97 7.3 that will most likely be stored in my parents shed is there anything i need to do to it before i leave
Swany45 is offline
post #2 of 3 Old 04-16-2013, 10:24 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
I put my vehicles on blocks and air down the tires. Shove a couple rags and cotton balls soaked in gasoline into the intake to hopefully keep rodents from moving in. Trickle charger on the battery (1 or 2 amp is plenty). I'd also run some fuel additive starting the month before storage just to keep the fuel sweet for a while. Diesel doesn't degrade like gasoline as long as it is in a sealed environment (filler caps tight).
Thank you for your service!
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 3 Old 04-16-2013, 11:47 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Put dryer sheets under the hood and in the cab, rodents won't eat your wires that way, thanks for joining, what branch you going to btw
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
